I made my new project E_S. This is especially sound 3D environment. The full version is not completed yet, but it does not matter, because full version will not be distributed.
You can download exe file(please read Readme.txt, recommended) and one sound track.
I relized that someone don't understand this project.
so, here is the definition of this project that I typed in elysiun.
so, you can read main point on web or if you hit the "A" key in "game".
The point of it is that you can build "song" through the use of your position in 3d space.
there are 8 big circles, every of them have 5 position. first position is mute, and the others four containing sound samples(in z axis). so you have 32 songs(every sound is spatial ). there are also 4 smalest circles. If you look at this whole object from uper side you can imagine that every one of the small circles is near to 2 big circles.
this small one can change the pitch of the near 2 bigest.
If you are moving thru this object you are bulding sound, especialy surrond sound in full version.( in full version I have also back channels that are corresponding with front channels, ofcourse this chanels is play the sound from rear of you). there are also cylinders that represents your movement above the circles, for better understanding where you were lastly.
this is something like a 3D alternative music instrumet that can play spatial sound through the use of avatar interaction.
I know the samples is no typical, this whole game(interface) isn't typical.
This is one of the main point of this project, build untypical interface "for build something" in this case sound("maybe interface of future").
it depends up to you what sound do you create.
You know I'm bored from game where you run and kill the others at all.
I hope that you'll understand....ufff
thx jm
I have seen multiple posts on this project and just had to take the time to stop and say I really like it. Very different, definitely not a "game" so to say. It also has a nice look to it.
