Weight painting and Vertex groups
grandall
Post by grandall »
I need to hide a vertex group to complete the weight painting for a bone. However I can't seem to find a way for the Hide function to work while in Weight Paint mode - version 2.6. Can anyone help please?
Many thanks, Graham
herby9ml
Post by herby9ml »
Hey, not sure if you got your answer already. But i believe, if you switch back into edit mode, and Hide the vertices; when you switch back, they should be gone. That's normally how i work that out. Weight paint normally mimics whatever you had going on in Edit Mode.
Anyways, hope that helps.
CoDEmanX
Post by CoDEmanX »
you can do what herby suggested and use that together with Vertex/Face Selection Masking in Weight Paint mode
grandall
Post by grandall »
Thanks guys for the replies - been on holiday hence the delays. I have tried what you suggest but even though the vertex group is hidden in Edit mode, as soon as I switch to Weight Paint mode the vertices appear again. Is this a problem with version 2.6 ?
CoDEmanX
Post by CoDEmanX »
rather a missing feature i guess
walldiv
Post by walldiv »
grandall wrote:Thanks guys for the replies - been on holiday hence the delays. I have tried what you suggest but even though the vertex group is hidden in Edit mode, as soon as I switch to Weight Paint mode the vertices appear again. Is this a problem with version 2.6 ?
i had this same thing going on, but i was able to solve it with ALT+B selection to select only a certain part of my mesh . . . but this was like an armpit or a tight crevace where i needed to get into the very middle of the 2 joining parts. If you have something overlaying the top of something else, IE: a piece of cloth over a table, or shirt/skin then i believe you have no option here :(
IF THAT IS THE CASE THOUGH. . . i have solved this problem by simply using SNAP TO FACE on the top lying element, and making its vertices that would touch the underlying element snapped to the face of the underlying.
i hope that makes sense, i could draw it out or show you the specific project i had that i did that with, and it inherited all weight paints after doing so, i didnt have any more bleed throughs or nasty mesh problems thereafter!!!
AvenidaGez
Weiight Paint and Vertex groups
Post by AvenidaGez »
I have posted a request
because, yes, we can use the restrict option, and great, we control what we paint is only in that vertex group, BUT, there is no option to update a Vertex Group, only Assign and Remove.
When you remove vertex there is no problem, but if you assign vertex then the weight paint is lost (reset to red), There is no way to update the vertex group, neither a way to copy/paste what you have already painted, so you assign new vertices to the group and can keep have you have already painted.
I think it woul be a good idea to have Update, Assign and Remove buttons
with update do not loose what you have already in weight paint.
