Crackling sound on VSE when fading in
Posted: Fri Jan 25, 2013 6:12 am
by NĂ©viton
Hi guys
I'm animating a sound strip volume to perform a fade in, but the fade in gets crackling while animating.
The problem persists even after rendering the strips to a mpeg video file.
Please, can anyone shed some light on this issue?
How can I get rid from those crackling noises?
Posted: Tue Feb 05, 2013 4:04 pm
by j kaulfers
Check your sample rate, not sure exactly where it is at right now, but you can adjust the sample rate. Note, like everything else increasing the sample rate increases render time.
If you can't get the results you are wanting by increasing the sample rate on the audio file then you may want to render just the animation and use an outside AVP to add your audio.
