transformation constraint
pixelmorph
Post by pixelmorph »
This is my first time posting on blender.org but I'm a little stuck.
I'm trying to use the transformation constraint to translate linear motion along the x axis into rotational motion on the y axis. I made a test file translating linear motion along the x and y axis and it works fine, but when I try linear motion along the x and rotational on the y axis it's not acting as I think it should. I would like to attach the files to this post but I don't see an attachment link? Can you attach files?
const
Post by const »
1. Create an Empty called Rotation
2. Create an Empty called Movement
3. Select "Movement" and add "Transformation" contraint
4. Set Values
Target: Rotation
Source: Rot
Y: Min 0, Max 360
Source to Destination Mapping: Y to X
Destination: Loc
X: Min 0, Max 360
Space: World Space, World Space
You can alter the Min Max values according to your preferences. :)
P.S. If you want file uploads then you can use Google Drive wich is available by default if you have Google Account.
