Audio with animation
Creamyyogurt
Post by Creamyyogurt » Wed Oct 25, 2006 9:17 pm
Is there any way for you to save Audio in the same animation as the rendered video or does it just save seperatly and you just have to put it together in a different program?
noodlesgc
Post by noodlesgc » Thu Nov 02, 2006 4:59 pm
as far as i know you cant render the sound into the video but after its rendered you can use the sequence editor to add sound later
solmax
Post by solmax » Fri Nov 03, 2006 12:39 pm
use the function "mixdown" to export all used soundfiles into a single one. You will need however an external program to combine video/audio. I suggest you use VirtualDub, works pretty straight forward.
Creamyyogurt
Post by Creamyyogurt » Tue Nov 07, 2006 2:21 am
Ok, thanks.
