Audio with animation
Creamyyogurt
Post by Creamyyogurt »
Is there any way for you to save Audio in the same animation as the rendered video or does it just save seperatly and you just have to put it together in a different program?
noodlesgc
Post by noodlesgc »
as far as i know you cant render the sound into the video but after its rendered you can use the sequence editor to add sound later
solmax
Post by solmax »
use the function "mixdown" to export all used soundfiles into a single one. You will need however an external program to combine video/audio. I suggest you use VirtualDub, works pretty straight forward.
Creamyyogurt
Ok, thanks.
