bf-blender / Windows (2004/01/23)
jesterKing
Site Admin
Post by jesterKing »
Todays CVS Build:
This CVS build has finally been obsoleted by a newer build
http://www.letwory.net/cvsbuilds/bf_ble ... 040123.zip
Again, this is build with the SCons, using MSVC7 as the compiler. It has TTF, International, Quicktime and OpenAL support compiled in. The ODE-powered gameengine is now available, no Solid yet. The build has been scanned for viruses and is found to be clean.
Number of commits since previous build:
* 12 commits
* last commit 2004/01/23 03:59:54 CET
The relevant parts from the CVS commit logs:
* (bug fix) raytracer fixed bug #903 where in some cases horizontal lines would show in a raytraced render.
* (feature) modelling New loopcut version, mostly by Johnny Matthews. More info at the end of this post.
* (bug fix) unified render fixed specularity calculation, as pointed out by intrr.
* (bug fix) unified render added clipping for spothalo rendering.
* (progress) image format Targa max. size is now 8192x8192
* (progress) particles Particles on a face's position are modified by the seed variable
* (bug fix) armatures fixed deformation delay in animation rendering.
* (bug fix) armatures bones get updated while pressing NKEY in pose mode.
* (bug fix) python API fix for home directory on some windows version.
* (progress) python API added set/getSize to the Object module.
* (progress) python API In the Armature/Bone module bone.set now accepts both n floats or a list of n floats
As promised a little more on the new loopcut version:
new features:
- after choosing a loop to cut you go into a second mode that lets you choose where exactly on the edge you want to cut.
the placement is in percentages, so 0% is one side of the edge, and 100% is the other side.
- holding CTRL snaps the placement to whole percentages. 1.00 instead of the standard 0.01 of a percentage.
- Pressing S while you place the cut turns on Smooth-subdivide for the cut (or as I like to call it: Loopcutsubdividesmooth
- the percentages and the ON/OFF for smooth cut can be seen in the view3D header.
fixes:
- loop takes into account hidden vertices, this solves bug #895.
- Cutpreviews are drawn correctly for triangular faces.
- renamed the function from loop -> loopoperations. I'm sure someone has a problem with the new name too, but BLAH! :D
- the parameters for the function are defines. loopoperations(LOOP_CUT) cuts, and loopoperation(LOOP_SELECT) selects (duh). this is changes in all the places the function gets called.
Enjoy!
/jesterKing
kirpre
Post by kirpre »
I'd been anxiously awaiting the new loopcut functionality being added to the bf-blender. I've tried it in tohuapu (spelling?) and loved it. Thanks again jesterking for all the builds. :D
niket
Post by niket »
Thanx For every build.. jesterKing.
From many time there is no interesting commit on yafRay front.. we are waiting for..! :D
Monkeyboi
Post by Monkeyboi »
The scripts in menus STILL don't show up unless I write a custom python path. The Blender/Scripts folder has quite a few scripts in it. I thought it should automaticly searh in Blender/scripts for any AS WELL as the Python path..
Anyone else experiencing the same thing?
Monkeyboi
Post by Monkeyboi »
Blender writes this when I open:
Expected default dir in C:\Documents and Settings\Administrator\Application Data
\Not a Number\Blender\.blender\scripts\ .
It looks to me like the path is absolute, not relative as it should be.
Oh and it still doesn't recognise the python path if there is a "\" at the end (which there is by default)
soletread
Post by soletread »
Is the light DIST slider maxing at 100 a permanent feature? How do we set a dist above 100? If I shift click and type in a value greater than 100 it resets back to 100. How do you change the effective dist beyond this then?
I have tried scaling the light and this does draw a longer dist indication in the 3D window, but doing this does not affect the HALO at all.
gabio
Post by gabio »
Again i got this when compile with your lib:
ftgl_static_ST.lib(FTPixmapGlyph.obj) : error LNK2001: unresolved external symbo
l __ftol2
blender.exe : fatal error LNK1120: 1 unresolved externals
scons: *** [blender.exe] Error 1120
If you don't know it's okay, look like scons isn't ready to be used by the community anyway...
lemmy
Post by lemmy »
Well...The Game engine works, except the framerate is about 1/3 of what it is in blender 2.25. Plus, the dloc works fine, but the LinV does not. Why is this? Also, great job jesterking, thank you for your daily updates. :D
He who laughs last thinks slowest.
Visit L3D for cool 3D stuff!
Home of Legacy of Taro, the 3d action/adventure samurai game.
jesterKing
Site Admin
gabio wrote:Again i got this when compile with your lib:
l __ftol2
This in itself has nothing to do with SCons. It looks more like a library is missing from your path.
jd-multi
Post by jd-multi »
What about a feature, when you close blender and your file isn't saved, a window popups and ask you to save or just quit. I always save before I quit, but there are times that I quit blender without saving, and then afther it think about "did I saved it?" :?
TorQ
Post by TorQ »
Whatever happened to wireframe view in face select mode?
TorQ
Thanks for the Daily Builds!
gabio
Post by gabio »
jesterKing wrote:This in itself has nothing to do with SCons. It looks more like a library is missing from your path.
Dho! Ok.. well What is this path you are talking about? sys path, python path, a variable, a file, maybe the source tree?
If there is only a place to specify, i'm will to write it. And the file isn't missing...
lemmy
Post by lemmy »
jd-multi wrote:What about a feature, when you close blender and your file isn't saved, a window popups and ask you to save or just quit. I always save before I quit, but there are times that I quit blender without saving, and then afther it think about "did I saved it?" :?
Yeah, definitely! And what about my question?
jesterKing
Site Admin
