Tuhopuu2 / OSX (2004/05/23) UV LSCM unwrap
Money_YaY!
Post by Money_YaY! »
Now, don't go crying and tell me it does not work faive days later. I need to know if it will start for you. Built on Panther no clue of jaguar
http://www.aprilcolo.com/oh/natch/simpl ... s/lscm.zip
Experimental support for LSCM UV unwrapping, as explained in:
http://www.loria.fr/~levy/Galleries/LSCM/index.html
http://www.loria.fr/~levy/Papers/2003/pg2003_hlscm.pdf
Currently the code only does the unwrapping part of the LSCM algo. LSCM also
includes some algorithms for full automatic unwrapping. This code is not quite
finished (not to say hackish :), but commiting it to cvs will ease
collaboration.
A conditional compilation option has been added to scons. In config.opts,
Setting USE_UNWRAPPER to 'true' will compile SuperLU, OpenNL and the
unwrapping code. A UNWRAPPER #define is used throughout the code for the
conditional compiling.
Some instructions:
- Press U > LSCM in faceselect mode to do the unwrapping.
- For marking seams, select the edges in editmode, and choose Make Seam from
the Mesh > Edges menu in the 3D view.
- Press L (Select Linked) in faceselect mode to select a seam group.
JA-forreal
Post by JA-forreal »
Sir, you are toying with me are you not?
Hey that's good news! Any chance of a Windows version coming out soon?
cekuhnen
Post by cekuhnen »
it works here on tatest os x
claas
shadowdragon
Post by shadowdragon »
It won't launch for me :( I'm on 10.3
JA-forreal
Oh man! It works!
I just tested it out by selecting some uv faces that are below the surface of a group of faces. It just spread the faces and flattened them perfectly. Now I understand that we will soon be able to just spread out the uv skin map of an entire object using seam selection etc. This is the stuff that uv dreams are made of! My thanks go out to all of the coders who are working on this fine project. I don’t see the “make seam” feature in my windows version.
Here’s to the best way of getting at digital nose and ear hairs on a 3d character!
Blend on!
Monkeyboi
Post by Monkeyboi »
It works, but I can't really get it to spread things out nicely. It just kind of curles some UVs down in the corner (testing with Suzanne)
Maybe you should call it 'Make UV Seam' or 'Make UV Mapping Seam' so that you don't create confusion (people could think the seams were a modeling feature).
Seamingly this has good potential (pun intended).
EDIT: What is the Pin feature for? BTW Relax is still uber cool, would like to see that in BF too.
JA-forreal
How do you get Relax to work in Tuhopuu? When I apply it I see no change in the uv's. I tried selecting the whole set of uv's and then parts but nothing happens. In the other 3d mapping apps that I have tested Relax uv's works as expected. Can you give me some tips that will help me to get the Relax feature to work in Tuhopuu? Thanks.
bjornmose
Post by bjornmose »
pinning tells LSCM the UVs to stay in place
(without manual pinning 2 UVs are choosen by some automagic )
so once you did a cylinder map, you can pin 2 (or more symmetric) UVs close to the seam to preserve symmetry and orientation
hmm . . results are sometimes surprising
depending on seams and pinning
.. just think of how many possibilities there are to peel an orange !
bm
bjornmose
Post by bjornmose »
JA-forreal wrote: project. I don’t see the “make seam” feature in my windows version.
Blend on!
did you DL tuhopuuNG? Mine is working.
edit mode header menu,
mesh->edges pop up menu, at the bottom
bm
Monkeyboi
Post by Monkeyboi »
bjornmose wrote:so once you did a cylinder map, you can pin 2 (or more symmetric) UVs close to the seam to preserve symmetry and orientation
Hmm can't really get it to work as expected. After doing an unwrap I select some UVs and pin them(they become red). Then I do a new unwrap. The pinned UVs get unwrapped together with the rest... Hmm, did I misunderstand?
blendix
Post by blendix »
Monkeyboi: The pinning at this moment is a little confusing. Now UV's are pinned, but only relative to each other. The result still gets moved and scaled into the image rectangle.
And yes, we need a hotkey for seam marking. Suggestions for it are welcome :D.
malefico
Post by malefico »
I said this at elysiun, but I'm so happy I don't mind repeating it here. This is great. UV Editor is now something very similar to what I dreamed a few months ago (Monkeiboy will understand me).
Seams are a perfect way to organize face selections too, not only for LSCM. I wanted face groups (instead of vertices groups which are uncomfortable to manage for this), but using seams and "L" to select groups of faces is a very comfortable and flexible way.
If you could add a little colour to faces selected in face select mode (instead of the barely visible lines), that would rock.
Maybe you could add the Make Seam option in the special W menu to make quicker access.
My hotkey suggestion: SHIFT + B (for Border if you like)
Cheers.
malefico.
JA-forreal
Blend on!
bm
I got it! It's all good.
cekuhnen
Post by cekuhnen »
i tryed out this tool since i understood it onyl 45 mins ago ;)
pretty cool i just ask myself why the heck the mesh gets distoreted in blenders UV mapper and still scaling totaly destroys the mesh structure.
it works like scale with fractal random translation.
claas
Monkeyboi
Post by Monkeyboi »
malefico wrote:If you could add a little colour to faces selected in face select mode (instead of the barely visible lines), that would rock.
This would be a huge improvement. It's very hard to see what you have selected in UV/Face Select mode! (In the 3D window..)
malefico wrote:Seams are a perfect way to organize face selections too, not only for LSCM. I wanted face groups (instead of vertices groups which are uncomfortable to manage for this), but using seams and "L" to select groups of faces is a very comfortable and flexible way.
Yeah, that's really nice, didn't discover that untill you pointed this out. Select Linked Faces is missing from the select menu in face select mode by the way. Not that I don't know how to press L, but for non-expert users I think it's important.
