bf-blender 2.34 pre Linux glibc 2.2.5
- Location: Somewhere below the rivers in Holland (but not Limburg)
finally Linux binaries for blender 2.34 pre testing.
Note that the package names are renamed by me, but the directory content of the package actually still refers to 2.33a. So beware not to overwrite any existing blender installation.
Please give it a test and report any misfeatures or possitive results back in this thread! Thank you in advance.
With regards,
Michel
With regards,
Michel
You can have one of two things: Progress or Progress Reports.
problem with libstdc++
it replies:
./blender: error while loading shared libraries: libstdc++-libc6.2-2.so.3: cannot open shared object file: No such file or directory
donn't know which version of libstdc++ can work with it, i'm using debian.
Re: problem with libstdc++
I'm using debian sid and it works well. The file libstdc++-libc6.2-2.so.3 is in the package libstdc++2.10-glibc2.2 .homebody wrote:it replies:
Generally, if a binary says that it cannot open a shared object file in debian you can search which package contains it from packages.debian.org
works mostly
Used the static version which seems to work fine. Yafray plugin did not work and crashed
blender, but i guess that is a blender bug.
Loading plugins ...
YafRay plugin loaded
Image allocated
Segmentation fault
used the new debian packages of yafray.
Loading plugins ...
Image allocated
Segmentation fault
Re: works mostly
The version of Yafray needs to be 0.0.7 which is to be released real soon, or has just been released. If that's the version you've used, and the problem still exists, you've found a bug! Please report back which version of yafray you've used. Thanks in advance.marpa wrote:Used the static version which seems to work fine. Yafray plugin did not work and crashed
Loading plugins ...
Image allocated
Segmentation fault
With regards,
Michel
Post Mortem Question, for Michael. (already asked in the Maillist, but got no definitive answer -not even close to definitive).
Michael, was there any specific reason why the Linux faq was not included in the 2.34 bundle?
http://www.blender.org/pipermail/bf-com ... 07109.html
Hi,Apollux wrote:Michael, was there any specific reason why the Linux faq was not included in the 2.34 bundle?
yes, the reason why the Linux faq was not included was because I had forgotten about them
I will try to remember to include them for the next release.
With regards,
Michel (not Michael
differences between linux version and windows version
Hi!
why the version for linux not have the blenderplayer?
why save runtime it does not work?
why???
sorry for my bad english
why???
Blender crash, if I use directly yafRay
blender crash with segmentation fault, if I use yafray directly from blender (wihtout using the .xml file)
I have downloaded this:
http://download.blender.org/release/Ble ... 386.tar.gz
and this:
http://www.coala.uniovi.es/~jandro/nona ... 86_sid.deb
I use debian sid.
Here is the backtrace (which I have obtained with gdb):
If I can help it more, let me know how (with which program, or which command of gdb)
Best regards,
Khiraly
and this:
I use debian sid.
Code: Select all
Starting scene conversion.
Scene conversion done.
(no debugging symbols found)...(no debugging symbols found)...
Loading plugins ...
Image allocated
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 2551)]
0x0842f310 in basic_string<char, string_char_traits<char>, __default_alloc_template<true, 0> >::replace ()
(gdb) bt
#0 0x0842f310 in basic_string<char, string_char_traits<char>, __default_alloc_template<true, 0> >::replace ()
#1 0x084c581c in yafrayPluginRender_t::writeMaterialsAndModulators ()
#2 0x084e83a8 in yafrayRender_t::exportScene ()
#3 0x084a028b in YAF_exportScene ()
#4 0x082563e1 in yafrayRender ()
#5 0x08256414 in render ()
#6 0x082572e2 in RE_initrender ()
#7 0x081889f9 in calc_renderwin_rectangle ()
#8 0x08188bd6 in BIF_do_render ()
#9 0x081c546a in do_render_panels ()
#10 0x081ac7c3 in do_butspace ()
#11 0x0819780d in winqreadbutspace ()
#12 0x0819b469 in scrarea_do_winhandle ()
#13 0x0813569a in scrarea_queue_redraw ()
#14 0x081361b0 in reset_autosave ()
#15 0x08136860 in screenmain ()
#16 0x080ee742 in main ()
#17 0x403a0dc6 in __libc_start_main () from /lib/libc.so.6
(gdb)
Best regards,
Khiraly
- Site Admin
Re: Blender crash, if I use directly yafRay
Hi,Khiraly wrote:blender crash with segmentation fault, if I use yafray directly from blender (wihtout using the .xml file)
and this:
I use debian sid.
this is a known problem. Yafray is compiled with a newer gcc and glibc than Blender. We're currently looking into solving this issue. The most likely outcome will be that Blender will be built with the same versions of gcc and glibc.
Until that time you'll have to recompile Blender and/or Yafray yourself to get this working. Sorry for the inconvenience.
With regards,
Michel
