BF OSX 10.3 (2?) HOOKS Feature 09/16/04
zbgump
Post by zbgump »
Cool, I've been wanting to try the hooks!
Problem though,
dyld: /Applications/Blenders/hooks/blender.app/Contents/MacOS/blender can't open library: /usr/local/lib/libfreetype.6.dylib  (No such file or directory, errno = 2)
Do I need to download freetype with fink?
solmax
Post by solmax »
same here. umm, any release logs? what hooks?
greets
marin
ElBarto
Post by ElBarto »
Take a look at the Windows-built posting;
http://www.blender.org/modules.php?op=m ... pic&t=4598
solmax
Post by solmax »
:shock: :shock: :shock: :shock:
whoaaaa. that's...amazing. just this dylib keeps bothering me, i installed freetype using fink and still doesn't work.. further investigation is on the way
solmax
Post by solmax »
ok got it working.. this is really amazing - the hooks and path deform are extremely useful - tentacles and such are a piece of cake now! (i've been trying to make a matrix-sentinel setup with regular bones - a pain in the ass, right now it seems wuite easy)
many many thanks to the developers.
just one "flaw" - path deform in combinations with hooks doesn't update the deformed mesh, unless i change frame. cpuld this issue be solved? that would be great.
marin
solmax
Post by solmax »
more problems:
i updated my spine using hooks and path deform - unfortunately it seems to work quite sloppy, "because" of multiple parenting/constraints/hooks etc. (find the .blend.zip at the bottom of this post)
brief description:
- a 2-point bezier curve is the "core" of the spine. it is controlled - for the sake of simplicity - by two empties ("hips", "neck").
- the curve itself deforms, using the new path-deform, a helper object ("spine.helper"), which consists of four planes stacked in equal distances.
- at each plane's center there is a cube ("v.1" to "v.4", also kind of a helper). each cube is vertex-parented to the corresponding plane
- finally, an armature with the same height as the "spine.helper" is utilized to provide deformation of the final mesh (not included in my file). each bone has a copyLoc constraint to the helper cube at it's start-position, and a track-to constraint to the cube at it's end position. bones are not parented to each other.
so, how to use? basically it should be enough to move/rotate the two empties to get a quite natural behaviour of the spine.
problems:
- update: none, not even after changing frame (OSX 10.3.5). the bones update only if you switch to pose mode and fiddle around in the constraints panel (like collapse/expand a constraint).
can you please test this to confirm that behaviour? and, can those issues be adressed and somehow solved?
get file here:
Money_YaY!
Post by Money_YaY! »
confirm. the bones do not move with the spline.
the bones are still in the plans from ton to add in..
solmax
Post by solmax »
ok, but what abt those update problems in general? even the combination of hooks and path-deform updates only after frame-change. is this "by concept" or simply because of beta-status?
best regards
marin
zbgump
Post by zbgump »
I've updated freetype with Fink, but I'm still unable to get this to launch.
Any ideas?
solmax
Post by solmax »
had the same problems. simply search the freetype lib, then have a look at the console to see where blender expects it, and simply copy the lib and the link to it in that directory.
you may alos need a jpeg lib, same procedure (update with fink, sréarch, copy)
