And as usual: Test.
relevant feature:
-Special request; Lasso Select (thanks andy for nagging!
-bugfixes
-Added undo menu for MetaBalls in edit mode
-New hotkey (test
-The long awaited first step (V0.01!) of SoftBody.
Commit:
-ton
Log:
Is committed now for further test;
What works:
- Hold CTRL while leftmouse-draw (gesture) for lasso-select
- Hold also SHIFT for lasso-deselect
- In Object mode it only selects on object centers now
- In Mesh edit mode it works on same level as borderselect
Not:
- other editmodes or objects in general
Also fixed crash with circle-selecting outside of window edge.
Also put back wire-extra draw for curves (previous trial broke mball wire)
Turned borderselect, circle, lasso into dashed lines for visual language.
Log:
Solved crash with;
- linked duplicate mesh
- subsurf on
- subdiv levels at 0
- new selectmode face + select clipping
Also found error in backbface draw when faces were hidden
-jri
Log:
- Added undo menu for MetaBalls in edit mode
-ton
Log:
Recoded how 'handles' were implemented; these were extra wireframe edges
actually, adding vertices and edges to displist.
Now the subsurfer gives editvertices a pointer to the subsurfed vertex
location; allowing not only vertices in 'optimal' draw to show correct, but
also gives proper handling of borderselect and lasso for edges.
Log:
- Made the 'zbuf clip select' in editmode default when reading on old file
- Added transparent wires in solid draw for editmmode, to denote selecting
clicks "through". Switching this and the zbuf-clip mode is actually nice!
- little annoyance; removed object centerpoint drawing in editmode.
-stiv
Log:
Tweak the bpy 'import site failed' msg.
A half-hearted attempt to make the World's Scariest Warning Msg
just a tad less scary.
-ton
Log:
- Improved memory system for pupmenu(), which now stores 255 entries max.
Meaning menus come back to previous selection almost always. Also fixed
annoying bug that caused Mirror menu (M in editmode) to start at 2nd item
- New hotkey (test
selectmode. I prefer this over cycling, since the menu is informing you
what happens.
- To enforce pupmenus to start at specific item, use pupmenu_set_active()
- pupmenu_col() to be done
Log:
- fixed error in lasso select (evaluated lasso coords one too many!)
- made ctrl+tab menu for selectmode only pop up in editmode mesh
- changed lasso code in zbuffer-select mode, that it also accepts lines
as lasso
Log:
Header redraw added for 'select mode menu'. Also checked more files for it.
Reminder, the allqueue() function needs as last arg a '1' if you want header
to be refreshed too!
-ton
Log:
OK. Here's the long awaited first step (V0.01!) of SoftBody. It is called
from within mesh_modifiers (kernel deform.c). It copies vertices to a
temporal particle system (struct SoftBody with BodyPoint structs) to do
physics tricks with it.
For each frame change the delta movements (based on standard ipo anim or
even other deforms (later) are applied to the physics system. How to apply
and calculate satisfying results is not my thing... so here I'll commu-
nicate with others for.
Since it's in the modifier stack, the SoftBody code can run entirely on
original data (no displists!).
Right now I've implemented 2 things;
- "Goal" which is a per vertex value for how much the current position
should take into account (goal=1 is without physics). This is a powerful
method for artists to get control over what moves and not. Right now i
read the vertex color for it.
- And some spring stuff, which now only works based on force moving it to
the originial location. This doesnt work with 'goal'... erhm.
- You can re-use physics vars from engine, used right now is (in Object)
- damping
- springf (spring factor)
- softflag (to set types, or activate softbody for it
- The SoftBody pointer in struct Object is only runtime, nothing saved in
file
To prevent all users going to complain it doesn't work, I've hidden the
functionality.
The buttons to set softbody 'on' only show now (psst psst) when the object has
name "soft" as first 4 characters. You can find the buttons in the F7 Particle
Interaction Panel (which should be renamed 'physics properties' later or so.
Demo file:
http://www.blender.org/bf/softbody.blend
-ton
Log:
Accidentally previous commit went out, while i tried to abort it.
This is a fix for propert circular clipping for circleselect, when it
uses backbuffer selecting
a new build is available.
