bf-blender / Windows (2004/10/01)
Yfkar
Post by Yfkar »
- New hotkey (test CTRL+TAB in editmode gives (and shows!) current
selectmode. I prefer this over cycling, since the menu is informing you
what happens.
I prefer cycling. I hate all extra popup menus. For example, if I want to quickly create a lamp I want to just press a lamp button, I don't like selecting the lamp type. If I want to use a lamp other than a normal lamp I will certainly go to the lamp properties tab anyway where I could easily select the lamp type.
I think that ctrl+tab should cycle the editmode and shift+ctrl+tab should do that reversed. With a popup menu I have to press an extra button every time I have to change the editmode. With cycling you have to press only once or repeat the same twice.
dgebel
Post by dgebel »
THANK YOU so much for edge, face selection and FINALLY, back-face culling!!!! :D :D
Mildly Unstable - Using Win XP sp2, this build, I was playing around with a bunch of the new features (about 21000 faces, 9.5M file created on with v2.3 I think), then tried to do something like turn off solid view and turn sub-surf off or on, not sure. But poof - Blender vanished. Haven't been able to repeat it, sorry.
About the edit selection type control keys:
It seems kind of redundant to have Control-tab pop up a menu, when "mouseable" options are on the icon bar thingie already.
Having said that, I sometimes like both the cycle between edit modes AND a pop-up menu. (Though I hate how Spacebar now changes the menu's sort order depending on where it pops up on the screen. ARG! :x ) But if there's a menu, should have a "Limit selection to visible" check option on there too, eh? Maybe the 3 modes should be on a pop-up instead of spread out like they are now. Then they would fit over by the MODE pop-up and the rest of the items more readily instead of stuck way off to the side. Hint hint.. :)
Er... but why is the back-face culling limited to solid mode? I'd love it in wireframe and OBJECT selection mode as well. Its a pain trying to pick out a simple object to edit while in a solid views, when there's a complex object underneath it - the complex object is the one that usually gets grabbed. I have to flip in back & forth between wire & solid view to find the edges to the object I'm staring at, sitting right on top.
Just grumbling, but I keep forgetting that F7 has been renamed to "object" panel rather than "animation" - I STILL can never remember where the object's layer buttons are.
jesterKing
Site Admin
Post by jesterKing »
dgebel wrote:Er... but why is the back-face culling limited to solid mode? I'd love it in wireframe and OBJECT selection mode as well. Its a pain trying to pick out a simple object to edit while in a solid views, when there's a complex object underneath it - the complex object is the one that usually gets grabbed. I have to flip in back & forth between wire & solid view to find the edges to the object I'm staring at, sitting right on top.
Because this is (currently)an opengl trick, which only works in solidmode. The solidmode gives a depth buffer (zbuffer) which is used for clipping.
/Nathan
Monkeyboi
Post by Monkeyboi »
But surely it could be moved so that it selects those same vertices in wireframe mode?
JA-forreal
Post by JA-forreal »
Wow! The new Outliner feature in todays CVS is amazing! I needed more scene management tools and I take a peek at the CVS and I find them in there. Thanks Ton! Thanks coders!
gabio
Post by gabio »
um um... ok then ;-)
Bellorum
Post by Bellorum »
Ooooh :shock: I'll have to try a compile tomorrow:) Did my first yesterday - ooh, the power I wield now. Muahahahahah :twisted:
