relevant feature:
-added curved lines as connectors, for Oops window
-ATI compatibily solved.
-bugfixes
-Cleanup of Rounded Theme;
-Version 1.0 of the new Outliner
-New option "passepartout" for drawing a darkened area around viewborder in Camera view
-New: outliner option "Show same type"
commit
-ton
Log:
Lots of small changes, all for UI in Blender;
----- Killed UI frontbuffer draw
The interface toolkit was drawing all live updates (while using menus/buttons)
in the frontbuffer. This isn't well supported cross-platform, so time to be
killed once. Now it uses *only* glReadPixels and glCopyPixels for frontbuffer
access.
Live updates or menus now are drawn in backbuffer always, and copied to
front when needed.
NOTE: it was tested, but needs thorough review! On PC systems I suspects
backbuffer selection to screw up (check!). On SGI/SUN workstations it
should work smooth; but I need evidence
----- Smaller fixes;
- AA fonts were garbled on ATI systems. Now the AA fonts are drawn exact
on pixel positions. Needs the new FTGL libb too, patch is on maillist
- Rounded theme uses antialiased outlines
- Pulldown and popup menus have nice softshadow now
- New button type 'PULLDOWN', thats the one that callsup a pulldown menu.
Should be added to themes, as is the full menu/pulldown drawing
- Screendump for 1 window does the full window now, including header
- Empty pulldowns (for example running blender without scripts) give no
drawing error anymore
For review & fun;
- added curved lines as connectors, for Oops window
Log:
Test for people which copybuffer method is best.
G.rt==2: uses a glReadPixel and glDrawPixel together
Otherwise it uses glCopyPixel (supposed to be faster
Log:
Fix for new UI system and vertexpaint/faceselect/weightpaint/texturepaint
If backbuffer is in use for selection codes, the system switches back to
frontbuffer drawing temporally. Is easier solution now.
Next commit; fix for new 'zbuffer clipped selection', which also doesnt
work after using a pulldown or popup menu.
Log:
Ack, buttons calling a pop up menu didnt flush!
-stiv
Log:
correct doc error for Curve.getControlPoint()
-ton
Log:
- pixel aligned clean AntiAliased outlines
- menu decoration integrated
And a fix for not drawing menu menubuttons pressed when clicking
-jesterking
Log:
updated FTGL lib with Tons patches.
-ton
Log:
The outliner is a hierarchical diagram displaying a list of data in Blender
and its dependencies. The 'databrowse' doesn't really show it, and Oops is
too chaotic still. And most of all, the former two don't offer much tools.
After discussions on irc, Matt came with this design proposal;
http://mke3.net/blender/interface/layout/outliner/
Which is closely followed for the implementation.
The current version only shows all 'library data' in Blender (objects,
meshes, ipos, etc) and not the 'direct data' such as vertex groups or NLA.
I decided to make it inside the Oopw window, as an option. You can find the
option in the "View" pulldown, or directly invoke it with ALT+SHIFT+F9
Here's a quick overview of the Outliner GUI:
- Header pulldown has options what it can show (Visible = in current layers)
- click on triangle arrow to open/close
- press AKEY to open/close all
- Leftmouse click on an item activates; and does based on type a couple of
extra things:
- activates a scene
- selects/activates the Object
- enters editmode (if clicked on Mesh, Curve, etc)
- shows the appropriate Shading buttons (Lamp, Material, Texture)
- sets the IpoWindow to the current IPO
- activates the Ipo-channel in an Action
- Selected and Active objects are drawn in its Theme selection color
- SHIFT+click on Object does extend-select
- Press DOTkey to get the current active data in center of view
TODO;
- rightmouse selection; for indicating operations like delete or duplicate
- showing more data types
- icon (re)design...
- lotsof options as described in Matts paper still...
Log:
Last fix for previous commit;
in Camera view. Provided by Wybren van Keulen.
Added button in F10 buttons, just above "DispView". Would like feedback
if this is a temporal or real feature
Log:
- Outliner: new items (on first show) come up collapsed now
- Outliner: click on Armature data goes in posemode
And long wanted, and found out is just a threeliner in code:
- Posemode: click-select-drag or grab-gesture switches to 'rotate'
automatic when no bone can be translated.
Log:
- Fix: enter/exit posemode used wrong pointer, could crash
- enter/exit posemode now updates outliner view too
- New: outliner option "Show same type". Shows only object types as
current active one. Nice to browse all lamps, mballs, armatures, etc
a new build is available
