2.I believe they should be same, but the 3 "make edge/face" functions different: choose 5 vertices of a cube, the "make edge/face" keeps silence, the "edges-make edge/face", "faces-make edge/face" and FKey popup FGon menu.
Good point:
3D View > Mesh menu > Make Egde/Face is broken, you cannot create an edge or a face with it.
i may not be doing this right, but if I have an empty parented to a curve, and I have the constraint, and I click edit on the constraint in the object area of the empty, shouldn't something appear in the IPO window? I was trying to make a fake DOF set up but I couldn't get the IPO curve to appear.
and I just have one issue with the global undo. When I do something like click through the frames in a 100 frame animation, I ruin the undo steps.
What about, when the user does something like change a color slider or click a number selector to change a value it only marks the start and finish values, not every value in between. That would be great.
