bf-blender 2.35windows(12-15-2004), Joystick Integration
snail
Post by snail »
Get it here
Edit: fixed the button problem and compiled with the current cvs
snailrose...
SirDude
Post by SirDude »
Post a cvs diff from the current cvs tree to the bf-commiters mailing list.
ZanQdo
Post by ZanQdo »
IT WORKS! :shock: :D
No problems by now, I use a simple "gravis" gamepad on xp :)
I normaly use an external python module named Joystick.pyd, it works fine but only one button or arrow/axis can be pressed at the same time. Your new sensor is perfect, thanks
snail
Post by snail »
SirDude wrote:Post a cvs diff from the current cvs tree to the bf-commiters mailing list.
thanks I submitted the diff
ZanQdo wrote:I normally use an external python module named Joystick.pyd, it works fine but only one button or arrow/axis can be pressed at the same time.
thats strange, have you tried the example here?
http://home.bresnan.net/~snailrose/tmp/files/mech.zip
ZanQdo
Post by ZanQdo »
mmm, yes you are right :? Mabe I do something wrong, heh. Well does't matter any more We got a built-in joystick sensor now 8) :wink:
Thanks for all
Edit:
Ups, I think I was wrong, the built in sensors also have the same problem, only one button can be pressed at the same time, I tried a simple example, a suzanne whit two joystick sensors, Button #0 to rotate and button #1 to move, they work but I can't move while rotating
snail
Post by snail »
thanks for pointing that out, i'll fix it and get a new one up :)
arangel
Post by arangel »
Snailrose, what´s the status of the joystick project?
Is it going to come back to CVS (2.36)?
Alexandre Rangel
Multimedia Designer
www.3Dzine.com.br
snail
Post by snail »
still trying :) I sent the code to Kester to check out
arangel
Post by arangel »
Thanks a lot! It´s very useful to have this feature in Blender !
Alexandre Rangel
Multimedia Designer
www.3Dzine.com.br
ZanQdo
Post by ZanQdo »
Great, thank you very much, it works with multiple buttons now :D
is there a patch?
