Just downloaded gabio's build on a pc in the lab here and it worked ok. Does it happen everytime or just in certain situations?William wrote:Am I the only one who can no longer move or scale edges in edge mode?
Martin
Ah, now we're getting somewhere.William wrote:I am using a new CVS version from Jan 23 on OSX. Maybe the transform code isn't enabled properly?
If you named correctly your object, you can find it very easy with SHIFT+F4joeri wrote:Is there going to be something to find small objects?
Scale the cube to 0,0,0 and you'll see what I mean.
Or is this an outliner thing?
Maybe shift-space can draw all object names. Or object names of (in outliner) selected objects.
In the previous version of blender objects would have an (ugly) centerpoint, regardless of datacontent of the object and regardless of scale. With removal of this centerpoint there will be a risk of creating invisible/lost objects in 3d view. Sometimes imat objects will have scale 0 and disappear, I'm asking if this (possible) problem will be adressed in the 3d view.Caronte wrote:If you named correctly your object, you can find it very easy with SHIFT+F4joeri wrote:Is there going to be something to find small objects?
