Bf-blender / OsX 10.3-CVS (2005-02-28) Experimental XCode
lukep
Post by lukep »
A new bf build (with new transform) is available here
http://jlp.nerim.net/dev/blender-CVS2.36--0228.zip
Important notice : this is a new build system using Apple XCode. When finished, this will allow non coders to build friendly from CVS as long they have the dev tools installed (which are free and included with Os X).
It is so very important to test that all functions works. This pass the regression suite but experience show that we cant catch all bugs this way.
no player. the texture and sequence plug-in may not work (not tested) but this is "normal"
Money_YaY!
Post by Money_YaY! »
I will test right away... But do you also have plans to implement this into tuhopuu ? Tuhopuu seems to be getting the most development right now .
Money_YaY!
first log:
size and move on the Y and X axis is really strange when in front andside view under flat and distort view (key 5)
stratacator
Post by stratacator »
Thanks for the build. So far the new transform looks great. I love that the finer grid snap (shift-ctl) is now actually usable. Also, I'm really excited about the Xcode system. Keep up the good work, everyone.
solmax
Post by solmax »
this is very good news, luke - i'll test it as soon as i can.
theeth
Post by theeth »
Money_YaY! wrote:first log:
I can't reproduce. It used to not work correctly in perspective mode (flat = orthogonal, distort = perspective, FYI) but that was fixed last sunday.
Can't you be more precise than "strange"?
Martin
- John Lennon
Money_YaY!
Martin
when did you start on osx ?? Just curious I thought you were windows builder/user
Anyway I have now tested it on two machines. Same thing.
make a cube change view to the front (key1) press S then press z<-- works fine, press x<-- works fine, press y<-- sizes and acts weird to infinity size in that axis ... all others size slowly and small like normal.
theeth
Post by theeth »
Uh? Where did I say I was working on OS X?!
The transform code is as platform independant as can be, the OS is irrelevent in the tests.
Money_YaY! wrote:Anyway I have now tested it on two machines. Same thing.
I can't reproduce at all. Maybe Jean-Luc did his build before my commit on sunday (though that would be surprising as the thread date is from yesterday).
Martin
- John Lennon
Money_YaY!
theeth wrote: Uh? Where did I say I was working on OS X?!
Oh I was just under the impression that all of your new transform stuff was only in tuhopuu. This build does not have the new widget if it is suppose to. Otherwise still testing...
lukep
Post by lukep »
can confirm here. it happens only in scaling from view facing Y (1 on pad). The value goes to infinity when selecting Y (but get back to normal value if you change the constraint). Now applying a constraint make no sense (you can view the feedback) but it is certainly a bug.
Now, it is the same build which is subject to the great build warnings massacre, ( 1000+ so far, 100 to go), so perhaps i borked something in the process. But i normally not touched the transform code.
theeth
Post by theeth »
Then I must have fixed it today. Could you check if it still does it after applying my latest commit?
Martin
- John Lennon
Money_YaY!
next note:
Do you have a dual g5 ? I tested the new threading feature but nothing seems faster yet.
lukep
Post by lukep »
theeth wrote:Then I must have fixed it today. Could you check if it still does it after applying my latest commit?
Martin
Still there. i have probable broken something when patching the warnings. not unexpected.
Sound like an unitialized var to me.
secundar
camera "Lens" -> "Scale"
Post by secundar »
Sorry if this has been covered elsewhere. I just opened a file with this build and noticed the camera was off - way off. I compared the file in the official 2.36 release and noticed a difference under the Editing button (F9) in the Camera Panel.
In 2.36 "Lens: 60.85" is now "Scale 4.21" in this CVS version.
lukep
Re: camera "Lens" -> "Scale"
Post by lukep »
secundar wrote:Sorry if this has been covered elsewhere. I just opened a file with this build and noticed the camera was off - way off. I compared the file in the official 2.36 release and noticed a difference under the Editing button (F9) in the Camera Panel.
Can someone confirm ? I dont have this here
