bf-blender / Linux (2005/03/11)
gabio
Post by gabio » Sat Mar 12, 2005 6:45 pm
Continue on the transform stuff this week. Note: the local constraint, planar constraint; with alt instead of ctrl. Lotsa bugfixes and the openEXR format suport. In case you don't know, "OpenEXR is a file format created by Industrial Light + Magic for storing High Dynamic Range (HDR) images."
p.s., you need to download and compile openEXR lib for blender to start...
Download it here
untar it and as root, do these command in the new rep:
./configure && make && make install
cp /usr/local/lib/*.so.2 /usr/lib
For more info on new tranform: http://wiki.blender.org/bin/view.pl/Ble ... efactoring
Done with gccand scons, glibc 2.3.5
Relevant feature:
- New Bpy type Text3d for accessing Blender's Font objects. (python module)
-Local axis constraint started. (transform refofactor)
-Wood/marble now have three waveforms to choose from: Sine, Saw and Triangle.
-bugfixes(2292, 2296, 2062, 2288, 2309, 2301,
-Gernot Ziegler's patch to add OpenEXR support to blender.
Commit:
-stiv
Log:
Contributed by Joilnen Leite (pidhash).
-ton
Log:
Fix & further implementation of Proportional editing;
- made generic 'calc distance' function for it
- added generic call to sort TransData with selection first, for speedup
of propmode calculus
- removed most propmode exceptions from code, only used for counting now
- all editmode transdata conversion function structured identical
-theeth
Log:
Works with edit data and in object mode with single selections (only one object selected).
Also started adding constraint stuff in headerprints. Only for Translation for now.
Pressing X,Y,Z (and the Ctrl versions) toggle between global, local and off like it used to do.
-stiv
Log:
fix warnings about implicit declarations.
overlooked by being in a hurry.
-ton
Log:
Patch provided by Chris Burt;
The Saw wave allows for much more realistic wood, especially in combination
with a ColorBand. A blender3d.org release page is being constructed about it.
Added: commit in editmesh_add.c to remove circle warning in face-select mode.
Log:
Bug fix #2292
Bumpmaps for skin on Env's dinosaurs appeared to be less nice in 2.36. This
was caused by the bugfix to make bumpmapping correct for rotations, which
should only work for flat/cube mapping. It also rotated it for sphere/tube
though, which gives less interesting bumps.
So; now the correction is skipped for tube/sphere mapping bumping.
-desoto
Log:
Tooltips for new marble buttons were from a copy/paste operation. This
caused error with... well... tooltips. icon_wink.gif First commit!
-theeth
Log:
+ Local axis constraint for multiple object selection works with resize and rotate (the easiest).
+ Refined the headerprint for Translation. Now prints only the needed info for constraint in the constraint's space (ie: if you're moving 1 unit along the local X axis, regardless of it's orientation, it will print "D: 1.000 along local X")
Still need to make numinput work like that (typing a number with a local axis constraint would move along that axis. There's some base code already though, just need a finishing touch, but it's late now)
+ Optimised PET calculations by using the TD_NOACTION flag (actually, that might have been in the last commit).
+ Added a float axismtx[3][3] member to TransData to store the orientation of the element (useful for local axis constrainst which, in edit could be moving along normals and the like).
- Fixed scaling in edit mode (was doing some matrix multiplications in the wrong order, only visible when using a constraint)
- Fixed the constraint projection matrix. It didn't work for planar constraint if the constraint space wasn't global (in a nutshell, it produced weird results for local space planes).
- Some potential bugs fixed (Note to Ton: added an ext pointer in TransInfo to point to the TransDataExtension block. With the sort done after allocation, the first td pointer doesn't necesarely point at the start of the ext block, so we needed another to free it correctly).
- Got rid of some remaining test with G.obedit.
- Moved constraint reset from init to post trans code (Ton, that means you can create constraints before calling transform, like for the menus for example).
NOTE:
I was getting some random segfault with the new headerprint code. Very random, couldn't reproduce with a debug version. I did some initialisation that might have been missing (though doubtful that's what caused the crashes). Was linked to using constraint though not caused by them. Probably due to some dumb late coding error.
-ton
Log:
New transform project;
- restored 'Warp' (Shift+W). Should work like before, including type mode
and holding ctrl/shift modifiers
- added CTRL event in queue, to only redraw when you press it. looks nicer.
-zuster
Log:
- replaced call to project_short_noclip with direct implementation
because project_short_noclip doesn't do the calculation if
the value would be near-clipped. For background picture we
don't care about this.
Log:
- switch draW_bgpic to calculate window coordinates as floats, smoother
zooming of background pic now.
Log:
Bug fix #2296
- Background image would jitter around on ATI card when zoomed in too
far. It appears that the driver is was multiplying the image width
by the zoom factor at some point and clamping this number, before
clipping the visible image. Somehow this then fed back in to clipping
the zoom factor.
Fix is to only tell GL to draw the smallest number of pixels (width
and height) that would be visible on the screen. Since this is not
a generally bad thing to do applied fix for all users of
glaDrawPixelsSafe.
Log:
- replaced min() by MIN2() and max() by MAX2()... my bad.
-ton
Log:
- Restored 'align mode', which allows rotate/scale with only object centers
Log:
Transform project; restored "auto key" after transform. It now inserts
always loc/rot/size ipos. The old method had a quite questionable
heuristic for detecting what changed, not sure if we want it back.
Added note in code, good candidate for later recode with dep graphs.
Log:
Upgraded buttons image
Log:
- Added more space in icons image (blenderbuttons.png)
It now only uses 1 extra row of 21 buttons. More can simply be added
- Added new icons for the new proportional edit options Root, Linear and
Constant
- Made sure pulldown and pop-up menu work for new prop options
- Transform fix; proportional edit circle was drawing in Object mode
Log:
Bugfix 2062
Stringcopy to a buf[32] without checking stringsize caused errors.
All credits for Martin P who found it. I'm assistant-committer. icon_smile.gif
-theeth
Log:
IMPORTANT NOTE: Locking axis (planar constraints) now works with ALT instead of CTRL. Ctrl might have caused problems in the long run, with people holding down ctrl for precision and then having to release it so to press an axis key if they don't want to lock it.
Finish adding local constraints for multiple objects: One of the objects will have its axis highlighted lighter than the others. You control this one with your mouse and the others copy the motion on their respective axis.
Code changes: the TD_OBJECT flag is now a flag in TransInfo with the new T_POSE, T_EDIT and T_TEXTURE
-sirdude
Log:
Found some messed up code that assumed abgr instead of rgba
In IMB_gamwarp which is used by the blur sequence plugin.
It should be fixed now. Also fixes a warning with gcc.
Kent
Log:
Removed Control-M's
bug#2288
Kent
-ton
Log:
Bug fix 2309
Move calls to exit editmode and posemode to "set_scene()". Was causing
errors when, in posemode, switching to empty scene.
-theeth
Log:
It's fun to set flags correctly and not have everything crash down on you.
-ton
Log:
Bug fix 2301
Halo render had too narrow clipping for left/right or top/bottom part of
image. Was caused by fix for 2.36, incorrect clipping for distance...
distance was OK, but the old hack should be still there for X or Y clip!
-sirdude
Log:
To enable it you will need to download OpenEXR and install it.
For the Makefiles you will need to set WITH_OPENEXR=true
and set NAN_OPENEXR to point to where OpenEXR is installed.
For scons you'll need to remove config.opts to get the new options
so you can enable OpenEXR, I was not able to get blender to link
with scons so the scons stuff may need to be tweaked a little but
I think it should work.
For other platform managers The OpenEXR stuff is similar to QUICKTIME
you need to define WITH_OPENEXR and setup the library stuff and
as you'll notice in this commit there are two extra files.
Kent
-zuster
Log:
- dna_error wasn't set on two errors in makesdna, allowed bad compilation
Log:
- made makesdna print how many bytes of padding should be added in
a struct on alignment errors, simplifies fixing.
a new build is available
JA-forreal
Post by JA-forreal » Mon Mar 14, 2005 7:35 pm
Are there any more details on Blenders usage of OpenEXR that we can read about. Are there any Blender OpenEXR samples that we can test out?
gabio
Post by gabio » Tue Mar 15, 2005 12:19 am
Not that much, it's a hight definition image format, you can save and load image with it. You'r lucky I could build it, it as been removed from the cvs temporairy, not well integreated, could not build on windows. visit www.openexr.com for more info
raphael
Post by raphael » Tue Mar 15, 2005 2:22 pm
Hello,
Thanks for this "openEXR special" built ;)
Saving an openEXR image seams to work. But if you load it, Blender doesn't display anything.
I made a build this week, and i had a bug. It appears in your built too, and it probably comes from the new transform system.
"Mouse wheel + grab" in edit mode makes Blender crash (segfault).
theeth
Post by theeth » Tue Mar 15, 2005 2:40 pm
raphael wrote:I made a build this week, and i had a bug. It appears in your built too, and it probably comes from the new transform system.
Gabio, could you provide a debug build, I'd very much like to trace that one to see where it's coming from. AFAIK, the is the last known crash and I can't reproduce at all.
- John Lennon
gabio
Post by gabio » Tue Mar 15, 2005 2:52 pm
Could reproduce here too on linux. But not on windows.
So where is this debug flag in scons :x
didn't really looked for it until now.
