bf-blender and Tuhopuu3 / Windows (2005/03/13)
SamAdam
Post by SamAdam »
Hello again all.
Some more work on transform and general work.
Done with cygwin.
The only thing that I have actually enabled is NEW_TRANSFORM, so if there is some other feature switch that I am missing just tell me.
crsrma
Post by crsrma »
..Is it common knowledge that these builds are not compatible with Yafray?
Nevertheless, it's great you're providing them for testing.
SamAdam
Post by SamAdam »
crsrma wrote:..Is it common knowledge that these builds are not compatible with Yafray?
i didn't know that...
well, i never said you should use them for real work, they are just for bug checking, I don't even use them, unless I need a new feature before gabio has it. I figured that I might as well just make the builds anyway, someone can probably use them. and they are slower too.
Bellorum
Post by Bellorum »
Yes, Cygwin builds don't go well with yafray, since they're not built with the same compiler. So if you want to use Yafray, don't use Cygwin builds. But everything else works.
SamAdam
Post by SamAdam »
i might be able to do a yafray build is anyone wants it.
JA-forreal
Post by JA-forreal »
SamAdam wrote:i might be able to do a yafray build is anyone wants it.
Thanks for these builds! Oh yeah, I would love to get my hands on a fresh Yafray build. I normally do a daily BF Blender and Tuhopuu build myself but I don't have much time at the present for this sort of thing. I have never been able to get YafRay to build with Cygwin.
SamAdam
Post by SamAdam »
well, yafray doesn't have make so it takes some extra work.
once i get scons working though it won't matter, I can just use msvc
crsrma
Post by crsrma »
Didn't mean to make more work for you, SamAdam. It's not really a problem, unless there happens to be something new to be tested that involves Yafray.
No real harm done, I'll just mess around with toxicX for now. :)
SamAdam
Post by SamAdam »
crsrma wrote:Didn't mean to make more work for you, SamAdam. It's not really a problem, unless there happens to be something new to be tested that involves Yafray.
i had to remove the builds.
sorry, but i can't use so much bandwidth.
and toxicx is defunct for right now, so you can ignore.
modron
Post by modron »
pardon my ignorance, but, what is 'transform'?
theeth
Post by theeth »
The transformation engine in general (grab, scale, rotate, warp, shear, ...).
Martin
- John Lennon
SamAdam
Post by SamAdam »
theeth wrote:The transformation engine in general (grab, scale, rotate, warp, shear, ...).
Martin
i am not so good at word matching.
