bf-blender and Tuhopuu3 / Windows (2005/03/13)
Posted: Sun Mar 13, 2005 10:51 pm
by SamAdam
Hello again all.
Some more work on transform and general work.
Done with cygwin.
The only thing that I have actually enabled is NEW_TRANSFORM, so if there is some other feature switch that I am missing just tell me.
Posted: Mon Mar 14, 2005 4:36 am
by crsrma
..Is it common knowledge that these builds are not compatible with Yafray?
Nevertheless, it's great you're providing them for testing.
Posted: Mon Mar 14, 2005 4:47 am
by SamAdam
crsrma wrote:..Is it common knowledge that these builds are not compatible with Yafray?
i didn't know that...
well, i never said you should use them for real work, they are just for bug checking, I don't even use them, unless I need a new feature before gabio has it. I figured that I might as well just make the builds anyway, someone can probably use them. and they are slower too.
Posted: Mon Mar 14, 2005 10:24 am
by Bellorum
Yes, Cygwin builds don't go well with yafray, since they're not built with the same compiler. So if you want to use Yafray, don't use Cygwin builds. But everything else works.
Posted: Mon Mar 14, 2005 5:51 pm
by SamAdam
i might be able to do a yafray build is anyone wants it.
Posted: Mon Mar 14, 2005 7:09 pm
by JA-forreal
SamAdam wrote:i might be able to do a yafray build is anyone wants it.
Thanks for these builds! Oh yeah, I would love to get my hands on a fresh Yafray build. I normally do a daily BF Blender and Tuhopuu build myself but I don't have much time at the present for this sort of thing. I have never been able to get YafRay to build with Cygwin.
Posted: Mon Mar 14, 2005 9:28 pm
by SamAdam
JA-forreal wrote:SamAdam wrote:i might be able to do a yafray build is anyone wants it.
well, yafray doesn't have make so it takes some extra work.
once i get scons working though it won't matter, I can just use msvc
Posted: Tue Mar 15, 2005 7:11 am
by crsrma
Didn't mean to make more work for you, SamAdam. It's not really a problem, unless there happens to be something new to be tested that involves Yafray.
No real harm done, I'll just mess around with toxicX for now.
Posted: Tue Mar 15, 2005 8:03 pm
by SamAdam
crsrma wrote:Didn't mean to make more work for you, SamAdam. It's not really a problem, unless there happens to be something new to be tested that involves Yafray.
i had to remove the builds.
sorry, but i can't use so much bandwidth.
and toxicx is defunct for right now, so you can ignore.
Posted: Wed Mar 16, 2005 1:07 am
by modron
pardon my ignorance, but, what is 'transform'?
Posted: Wed Mar 16, 2005 1:41 am
by theeth
The transformation engine in general (grab, scale, rotate, warp, shear, ...).
Posted: Wed Mar 16, 2005 3:02 am
by SamAdam
theeth wrote:The transformation engine in general (grab, scale, rotate, warp, shear, ...).
i am not so good at word matching.
