update: new interesting stuff again. Also take note you need to reinstall the .blender dir if you wasn't, important change made.
For more info on new tranform: http://wiki.blender.org/bin/view.pl/Ble ... efactoring
Done with MSVC 7 and scons!
Relevant feature:
-Revive: Individual Element (object) center for Rotate and Resize
-python: patch submitted by guitargeek(texte3D module) include new stuff.
-bugfixes(2123,1655)
-Added new script menu entries
-Updated menu registration so that scripts folders can become trees
-Transform widgets; Scale and Rotate versions
-python: Added Blender.Run(script) + doc update
-New Bpy Object method: insertIpoKey()
-New Material method: insertIpoKey( key_type )
-Initial integration of CCGSubSurf library into blender.
---update---
-Scripts (making some changes to the scripts dir)
-widget UI tweak:
--added 'ghosting' for while using translate/scaling widget
--added 'pie chart' ghost to denote angle while using rotate widget
--added settings to tweak widget in User menu (InfoWindow) "View & Control"
--Size: total widget size as percentage of window size
--Handle: as percentage of widget radius
--Hotspot: for clicking handles, in pixels
--Fized Size: option to make Widget size independent of window size
-widget: now support for global/local/normal orientation.
Commit:
-theeth
Log:
Individual Element (object) center for Rotate and Resize. Note that using this in edit mode is a bit useless right now, but we have some surprises in our bozo bin
Transform can switch mode on the fly again (GRS).
Fixed a bug with the BIF constraint call, needed to call startConstraint and normalise the space matrix (this affected the manipulator).
-ascotan
Log:
- patch submitted by guitargeek
-includes:
*Text3d accessors - ablity to manipulate FONT objects through python
*update to Object.link - calls text_to_curve upon ob_font link for drawing
*update to constant.h - constant type checking define
*update to curve.c - clamp values on getters/setters
*clean up of Text3d module
-ianwill
Log:
BPython:
- Scripts:
fixed error in "Save Current Theme" which prevented it from automatically updating script registration in menus.
cosmetic changes in a couple of Campbell's sel_same.py script strings + more descriptive name for its new menu place (3d view, face mode -> select menu).
small updates to help_browser.py script.
The above changes are related to this:
- Added new script menu entries: Render (for exporters to renderers), Themes, FaceSelect (this already at the proper place). Updated Scripts win->Scripts menu so it won't show all available entries, only the ones we mean to see there.
- Updated menu registration so that scripts folders can become trees. The release/scripts/ dir should be updated soon with subdirs like converters/, modifiers/, generators/ or whatever -- better discuss first (or is it? /me afraid of long irc discussions during meetings
- Modules:
Blender: added 'udatadir' option to .Get() function and added var Blender.mode to tell if Blender is in bg or interactive mode.
NMesh: added Campbell's nmesh.transform(matrix, recalc_normals = False) method (reworked, so my fault if it doesn't work).
- Bugs fixed:
#2123: http://projects.blender.org/tracker/?fu ... group_id=9
Reported by Ken Hughes (thanks!), who also found the exact problem later (it was in Text.Load, not with script links -- if only I had checked emails these days ... lost > 1 hour today to find the problem: passed filename to M_Text_Load was later being written over by a function called by add_text). Also saw that Text.Load wasn't checking existence of passed filename (duh!), now it does.
#1655: http://projects.blender.org/tracker/?fu ... group_id=9
Reported by Chris Want (thanks!): command line "blender -P script" not working properly for bg mode ("blender -b blendfile -P script").
Had to make some small updates to get it working (bg mode for scripts was never explicitely handled, it worked due to collateral effects, let's say), interested readers can check the report after I update it or the API_intro.py doc file. After more testing we can make further updates. Updated many places to not call redraws if in bg mode, now it is officially available. Blender outputs its own info when rendering in bg mode, if that is considered a nuissance we'll have to add a few "if (during_script())" calls outside bpython.
- Removed a few warnings here and there and also updated docs.
-ton
Log:
To use; press the (temporal) icon in header. Switching widget types is by
pressing G, R or S once, if current widget type is different it switches,
otherwise it goes to normal Transform().
Widgets need a bit test for picking accuracy, correct drawing etc.
The rotate widget has a center button for 'trackball' rotate. That latter
can also be used for hotkey-based rotate.
In current code, all widgets remain in "Global" space, also in editmode.
Also widget updates while using normal transform has to be done.
2 Bugfixes:
- rotate in PoseMode had error for 2d 'around' center
- transform in postemode could crash, due to typo (& or |)
-ianwill
Log:
BPython:
- Added Blender.Run(script) + doc update (forgot to mention in my previous commit).
Trying to fix two mistakes from my previous commit:
- nmesh.transform(): forgot yesterday that affine vectors have 4th component = 0, now updated normals transformation accordingly.
- As Ton pointed, recursive parsing of scripts dirs in search of scripts was a mess. I simply forgot about the "//" trick and much worse, to protect against worst cases ("/", for example). Now the code uses BLI_convertstringcode to take care of "//", doesn't process if dir = "/" and there are limits:
max depth for traversing subdirs = 4
max dirs in the tree = 30.
I'll work more on this, check more, but these changes were tested and should make the code safer, of course, so I'm committing. Sorry about the mess, I should take lessons on defensive programming ...
-ton
Log:
New version of rotate handlers. I like it! Now the rest of you
Log:
Little fix; while Transform() in editmode, and other objects were select,
these objects were drawn in transform color (white usually)
-zuster
Log:
Some cleaning up of BLI_winstuff.h usage
- removed reference in render.h (really bad, shouldn't include a platform
specific header so widely unless really necessary)
- added M_PI, M_PI_2, M_SQRT, M_SQRT_2 defines to BLI_arithb.h... this is
a better place as it is more the "standard" blender math header. left
in winstuff.h as well for the moment for simplicity
- other changes are patches to code so everything works ok with this
shuffling.
-ton
Log:
Global G.moving got nice define flags, and additional meaning.
- move object mode
- move editmode/pose mode
- move with widgets
-zuster
Log:
- add some windows specific defines to BIF_gl.h so that OpenGL can
be used without including windows.h - this is the main reason windows.h
is included in so many places and this change allows most of those
inclusions to die.
Log:
- remove all obsolete inclusions of BLI_winstuff.h (due to recent changes)
NOTE: BLI_winstuff.h was meant to be a wrapper around windows.h to handle
undefining various crap that windows.h defines. Platform specific headers
should only have to be included in a few places. This reduces the number
of inclusions of BLI_winstuff.h to 16 which is a much more reasonable
number (than the 144 or whatever it used to be)
-stiv
Log: (python)
fix warning: initialization makes integer from pointer without a cast
-ton
Log:
- added helper lines in rotation widget
- switched to Local mode for widgets by default, will be a key/button later
-stiv
Log:
inserts Object IPO key for LOC, ROT, SIZE, LOCROT, or LOCROTSIZE
Contributed by Johnny Matthews (guitarGeek)
-theeth
Log:
Ton broke a couple of things in his last commit including PET in rotation mode and local axis constraints on objects.
Bringing that back and enabling PET in trackball rotate.
Changed the rotation manipulator drawing code to really align the Trackball rotate ball with the view (using getViewVector) so that it always looks centered on the selection.
This was particularly ugly in perspective mode with a selection far from the center of the screen: http://www.clubinfo.bdeb.qc.ca/~theeth/screenie.jpg
Moved getViewVector from transform_constraints.c to transform_generics.c since it is not really a constraint related function. Also made it independant on the TransInfo structure so it might be useful elsewhere too.
-guitargeek
Log:
Adding some docs for Text3d additions
Log:
Adding some docs for Object insertIpoKey additions
-ton
Log:
- Fixed flipped orientation of getViewViewvector(), was opposite in ortho
versus perspective.
Note for Martin; still an issue with defining what positive/negative
rotation is in perspective... needs more math here!
- Added Transform Widgets for PoseMode
- made adding bones in EditMode setting G.moving, so it doesn't draw other
selected objects nor Widgets
Warning in commit of Martin yesterday: Trackball and initTrackball were
declared static, whilst also in transform.h. Quez; why are these functions
exported in the .h file?
-stiv
Log:
correct bad reference to getDrawMode.
-ton
Log:
Three rotate manipulators to play with;
G.rt = 0: one handle for each rotate axis
G.rt = 2: traditional half-circle rotate handles
G.rt = 3: mixed version
(rt is the general debug var in render button, just under "render sequence")
-stiv
Log:
inserts material ipo key at current frame.
contributed by Johnny Matthews.
-guitargeek
Log:
Adding some docs for material insertIpoKey additions
-zuster
Log:
- apologies, accidentally commited code w/ game engine disabled
Log:
- kill some warnings (open/seek/read/write need io.h on win32)
-theeth
Log:
Warp was acting weird if the cursor wasn't centered in the data space, that is fixed.
Helpline for warp was wrong in edit mode if the object wasn't centered on global space.
Boundbox calculation for warp is done in view space now, so it is always maximised since aligned with the view.
Switch the negative/positive switch for Shrink/Fatten from horizontal motion to vertical motion. Pull down to shrink, pull up to fatten. This could still use some work.
BugFix: Constraint center was wrong with MMB (was bypassing the fix I commited the other day).
BugFix: Changing modes while in transform and switching to local constraints in edit mode crashed. This was due to resetting the TransInfo flag in initTransModeFlags. Now done correctly in initTrans.
Log:
- Initial integration of CCGSubSurf library into blender. The lib is
only in one C file and not worth dropping in extern but presumably
will be synced with public CCGSubSurf release I hope to be making
soon.
- Currently the implementation must be enabled by defining
USE_CCGSUBSURFLIB somewhere with your build system. The code should
be considered highly experimental.
Log:
- Part of CCGSubSurf integration, this is the actual blender side of the
integration.
Log:
- remove some duplicate prototypes, causes problems for some compilers
---update---
Log:
- update new conversion to DLM routine to use match subsurf
(means optim, seams, selection should work same now, but I am
not super familiar with all this stuff so can't test very well).
These hacks to the DLM structure are disgusting btw Ton. What
a waste of memory! All the information that is so meticulous to
kept and managed in the old structure is essentially explicit (or
easily made so) in the new one.
-ianwill
Log:
Scripts (making some changes to the scripts dir):
- moved bpydata/ to scripts/bpydata/ and added a config/ subdir to it;
- created scripts/bpymodules for py modules (also got rid of those "mod_"'s appended to the files);
- updated scripts accordingly.
This will require you to "reinstall" (just copy the scripts/ dir over your older one) if you have a .blender/scripts/ dir somewhere. Otherwise some scripts won't work. You can use the updated "Help->System->System Information" script here to check all is fine. An installer script yet to be written will help users with these issues, specially to make the user defined dir have the same structure expected from the default scripts dir, so the basic facilities (module search; saved config data; scripts: installer, help browser, config editor) are also available for a user's own collection of written and downloaded scripts.
BPython:
- slikdigit's crash was because he had no <home or blender exe location>/.blender/:
proper check added and also now if all else fails the <cvsblender>/release/scripts/ dir is also searched for scripts. All this registration dirs stuff is a little messy (installation!), so please report any troubles (I only tested on linux).
- slight change in error report in BPY_interface.c's BPY_menu_do_python; remembering to set globaldict pointer to NULL there, too.
- moved bpy_gethome() to EXPP_interface.[ch]
- "//" as user defined python dir is ignored while looking for scripts, considering it's only a default some users use, not really meant for a scripts dir.
-ton
Log:
More transform widget goodies;
- added 'ghosting' for while using translate/scaling widget
- added 'pie chart' ghost to denote angle while using rotate widget
- added settings to tweak widget in User menu (InfoWindow) "View & Control"
- Size: total widget size as percentage of window size
- Handle: as percentage of widget radius
- Hotspot: for clicking handles, in pixels
- Fized Size: option to make Widget size independent of window size
Not sure if all of these are useful to keep, but makes for good testing
in this stage.
Also: made #define to use new transform to be set TRUE by default now. *sheer*
Log:
Transform:
- cleaner code for selection of handles in transform widget. in ortho views
selecting the center handle defaults, to prevent Inf. overflows for
perpendicular handles. While holding SHIFT it works the opposite!
- removed redraws on modifier (CTRL, SHIFT) key release. that ensures you
can apply to grid nicely (functioned that way in all blender releases)
-theeth
Log:
Shrink/Fatten behavior change. This time for good I hope.
Technically, it now works by getting the mouse motion in 3D (just like Translation/Grab), projecting it on the vertical view axis, using the vector length as the shrink/fatten factor. If the motion is downward (on the screen), shrink, if it is upward, fatten.
In layman terms: move up to fatten, down to shrink and it adapts to the viewport zoom, like Translation.
I changed to snapgrid factors to match those of Translation to, so it really acts like grabbing.
-ton
Log:
Added string to BIF_setSingleAxisConstraint() function for headerprint.
Needed for martin to further work on print stuff
-theeth
Log:
Created initConstraint. It basicly just checks if the CON_APPLY has been set up (by the BIF_setConstraint calls for example) and calls startConstraint. This must be done because startConstraint uses data initialised when starting transform so it needs to be called after that.
Also changed some strcpy into strncpy.
Log:
Fix for possible divide by zero error in Rotate.
Fix for MMB behavior when two axis were exactly on one another or very close. It now defaults like this: X, Y, Z (meaning if as near as X as Y, it chooses X). This could be fixed further.
Log:
Size flipping, for kaito. Move pointer to the other side (horizontal) of the pointer to see. (Does affects size member, so just object position and edit mode)
-ton
Log:
Transform widget update
- now support for global/local/normal orientation.
- LMB click on center switches orientation mode
- in object mode, local (now) only displays on single object selected
- in editmode, Normal orientation is derived from faces selected
- if no normal can be found, it shows local orientation
Currently implemented, for test, in Mesh editmode and PoseMode.
Note for PoseMode; the 'translation widget' shows on "IK" bones but
doesn't translate, it rotates instead. Pretty interesting to use the
translate widget for it...least cluttered display I think.
Note for Matt; I tried MMB click for switching orientation... it's just
weird that way... such clicks, repeatedly, with mousewheels isnt nice
either.
a new build is available
