Tuhopuu3 / Windows (2005/04/07)
JA-forreal
Post by JA-forreal »
Yes thanks Gabio and much thanks to joeedh. I have been alt-cing jumping in and out of "He mesh" mode converting back and forth crash free unless I try some crazy bridging stuff. This stuff is great! I'm testing it out for a new shake at city environment building. Using this new method in combination with using the new bridge feature for cuting windows and standard mesh knife cuts for building the frameworks for walls and doors, I can speed up my old way of working! I'm going to add this new style of workflow to my Blender production setup. Wow!
Blend on!
venomgfx
Re: Tuhopuu3 / Windows (2005/04/07)
Post by venomgfx »
gabio wrote:---------------------------------------
This package containe only the latest bin:
Download me!
yay!! Dial up users says thanks! :D
ZanQdo
Post by ZanQdo »
WOW the new sub-surf weights are extremely good :shock: :shock:
I like the way widgets are implemented :wink:
oyster
Post by oyster »
bug:
plz check bullx's http://www.idstudio.it/bullx/blender/soft_test.blend. It does not do sb in this build
bleen
Post by bleen »
hey gabio...a very cool build!!!
i like the "new" way of the turntable rotation, it´s now like normal apps ;)
keep the work up!
bleen
btw: widgets: i miss a centerpoint for "free" grab!
rednelb
Post by rednelb »
guys, guys! thank you very much for the turntable!
matt_e
Post by matt_e »
Pierre-Luc_Auclair wrote:Could normals be displayed with a gradient colour ? Like the combo select types ?
Yep :) Not a bad idea, could help to see the direction better. Now testing it in tuhopuu cvs.
Zsolt
Post by Zsolt »
Just a small, but in cases very useful idea:
Could the Show Edge Lengths be modified so that the edges which are only "half-selected", ie: one end vertex is selected, also show the length?
I mean when I need precise modelling, I modify an edge by moving one end vertex, and I want to be able to see it's length change as I move it, which doesn't happen in the current version. I would give a BIG THANKS to any coder who could change this! :)
DYeater
Post by DYeater »
Zsolt wrote:Just a small, but in cases very useful idea:
Funny you should mention that ...
Check this out
Great minds think alike? :)
JoOngle
Post by JoOngle »
First off ...
The BRIDGE tool seems absolutely GREAT (when it doesnt crash...wich it does 95 percent of the time).
Can´t wait until this modelling mode becomes a part of Blender (when it doesn´t crash all the time).
Great effort guys! :D Looks really exciting!
Edit: More bugs...
- When you try to animate, and you "leftarrow" back to say...frame -59
and Alt + A (animate) , the animation counter gets all garbled (lots of pixels ...like displaying another graphics area...in form of pixels...pretty much like a commodore-64 sprite without graphic-data)
until it reaches frame 1 and counts normally.
Delta
Post by Delta »
following up on joOngle's post...
i for one am very annoyed at the fact that [downarrow] can now take you into the negatives, as this is rather confusing...
but its just a small gripe of mine
Regards,
~Delta
Zsolt
Post by Zsolt »
DYeater: I guess they do :) Thanks for the link to that thread!
Another teeny-weeny little thing: the center circle has disappeared from the translate widget, which is good, you can now see the vertex you're moving. But now there's no way to switch coordinate systems (local/global)! You have to switch to another widget, click on the little ball, and then cycle back with ctrl.
This issue I think awaits a real solution for all the widgets, like a button on the header, or for example the "hand" icon could be a popup menu to select the coordinate system.
btw: the bridge tool crashes all the time for me too. But other than that, HE mesh is great!
edit: negatives bother me too! I actually see now use for them.
I got used to simply holding down the down arrow or the left arrow to automatically cycle back to the first frame, well, not anymore. Sometimes I need something to start in the negative numbers, but that has been possible before, too (like moving IPOs to negative frames).
joeedh
Post by joeedh »
JoOngle wrote:First off ...
Do you mean it crashes Blender, or that it pops up an error message saying "Unsolvable Mesh"? if the latter, then the problem comes from the orientation-solver I wrote (which needs to be fixed).
joeedh
JoOngle
Post by JoOngle »
joeedh:
It Crashes completely (no error messages, just boom-gone)
ysvry
Post by ysvry »
yes had it crash too after bridge.
