bf-blender / Windows (2005/05/06) Multiple Monitor patch
jesterKing
Site Admin
Post by jesterKing »
a build with a small patch which allows you to open blender stretched over 2 or more monitors at start. This zip contains only the blender.exe. Further this is a cvs build from against CVS this day 1200 EEST.
To test: make sure your desktop is stretched over all your monitors, then start blender with:
blender -w -p 1 1 x y
I start for instance with: blender -w -p 1 1 2560 768
Note that this will work only if you have a gfx driver with accel support for all monitors. Bad drivers result in performance degradation in the interface. I have a NVidia FX 5600, and Blender stretched over both monitors works like a charm for me.
Link: www.letwory.net/downloads/multimonblender.zip
Please report in this thread your results. NB: also people with only one monitor are invited to test - if blender starts without problem, then everything is fine :)
/Nathan
joeri
Post by joeri »
jesterKing! Hooray!
Nomadigin
Post by Nomadigin »
I have two monitors and before I get too far with patching blender I have a question: Does this build work if the monitors are set to different resolutions? They aren't greately different but they are different.
jesterKing
Site Admin
The bounding box for the entire virtual area will be used, so give the smallest height and you should be able to use blender quite well. Before using this I suggest you backup the original blender.exe :)
/Nathan
jesterKing
Site Admin
joeri wrote:jesterKing! Hooray!
Does this mean it worked? :)
/Nathan
jesterKing
Site Admin
I must add that this most likely won't work on win 95 and winnt 4.0 I'm not sure about either... So test results please :)
/Nathan
LeeQid
Post by LeeQid »
No go here.
Win XP Pro
ATI Radeon 9800 Pro (Catalyst 5.4), dual head
Monitor 1 1920x1200
Monitor 2 1280x1024 (pivoted)
Monitor 2 is _left_ of Monitor 1 with the top edges lined up.
called blender with:
blender -w -p 1 1 2944 1200
As soon as I open up a menu everything goes wild until closing the menu again.
jesterKing
Site Admin
Thanks for the info. I'll look into the different monitor setup possibilities when I get home.
/Nathan
alltaken
Post by alltaken »
jesterking a nice sollution to the whole backing up the blender.exe file is to rename the new one.
from the same directory you can have as many different builds as you want.
i commonly have blender.exe (as the BF build)
then the intel optimised one i will just call blenderintel.exe
etc....
i hate to think what the b.blend file is like if their are differences in writing to that, but it generally works well.
/me wishes he had another monitor right now, this feature looks good
Alltaken
joeri
Post by joeri »
/Nathan
It means I'm glad to you're back.
I don't have a dual display setup. :(
Actualy I have a dual display output on my card, I just don't have 2 monitors.
meestaplu
Post by meestaplu »
This might just be me being stupid, but what exactly is the issue with Blender and multiple monitors? I used Blender 2.23 on 19 inch CRTs in high school -- that was two and a half years ago. It worked great then -- what's the issue right now?
While we're on the topic of multiple monitors, has anyone had any luck getting Blender working on a 30 inch Apple cinema display?
Matt
I love vector calculus at 4 in the morning.
Aaltje
Post by Aaltje »
Thanks works great on a Geforce 4. Now I don't have to resize every time I start blender. Just be sure it is included in 2.37!
Thanx
Alex
RRuiz
Post by RRuiz »
Nop, It do not work for my NVIDIA QUADRO4 550 XGL :( :(
I see in the second monitor the typical Black part for the blender window
Un Saludo
kidb
Re: bf-blender / Windows (2005/05/06) Multiple Monitor patch
Post by kidb »
jesterKing wrote:Hi,
Could you supply the patch? I use blender under Linux and MS Win stretched over 2 Monitors, hmm?
SirDude
Post by SirDude »
Jesterking and I made some modifications. I'll post the
latest in the patch tracker. Jesterking still might
not be online all that much currently and asked me to work on it.
