Tuhopuu3 / Windows (2005/06/06) CygWin *UPDATED*
Bellorum
Post by Bellorum »
It's been a while since anything interesting was added to Tuhopuu, but I figured a build was justified by the latest commits. Built with CygWin.
Noteworthy commits:
-Last merge with bf-blender on may 29
-UI tweaks
-Broken's customizable toolbar
-Tweak back to drag and release (like it should be :x )
Updated on june 6. Merge with BF-Blender jun 5. Themes from BF-Blender can now be used again.
I'll just leave you to read the CVS-logs now :)
broken (Matt Ebb) 2005/06/04 07:56:50 CEST
Modified files:
tuhopuu3/source/blender/include butspace.h interface.h
tuhopuu3/source/blender/src buttons_editing.c buttons_object.c
buttons_scene.c editmesh_tools.c
editobject.c
Log:
Buttons stuff again!
* Decreased the size of the panel header, and the margins within
and between panels
* Added a 'tool settings' panel in edit buttons (mesh edit mode)
with *all* number inputs for tools that require them. The settings
are persistent, so for example you can set the subdivide fractal
percentage once, then just click the button, instead of having to
do it every time. Activating these from the menus also uses the
values in the panel as the defaults in the popup.
* Trying Chris' (thanks!) edits to the render buttons/dimensions
panel, for less wide-and-chunkiness.
* A few post-merge tweaks
broken (Matt Ebb) 2005/06/04 09:14:07 CEST
Modified files:
tuhopuu3/source/blender/blenloader/intern readfile.c
writefile.c
tuhopuu3/source/blender/include BIF_interface.h
BIF_resources.h BIF_space.h
BSE_headerbuttons.h
tuhopuu3/source/blender/makesdna DNA_userdef_types.h
tuhopuu3/source/blender/src drawview.c header_view3d.c
interface.c interface_draw.c
interface_panel.c resources.c
space.c toolbox.c usiblender.c
Log:
* Customisable toolbar
See: http://mke3.net/archives/2005/06/blender_toolbar.html
for demo videos and more detailed information than I can fit in
this commit log!
Currently, it's only working for the view/select/blah menus for
object mode and mesh edit mode. Support for other modes can be
added very easily, it's just a matter of time and manual labour,
which are in short supply right now, so I thought I'd at least
commit this and the rest can come later.
theeth (Martin Poirier) 2005/06/04 11:18:40 CEST
Modified files:
tuhopuu3/source/blender/include BIF_transform.h
tuhopuu3/source/blender/src editobject.c transform.c
Log:
Added a transform context option for Tweak mode. So, right clic, drag and release works again, as it did for a while.
broken (Matt Ebb) 2005/06/04 15:53:19 CEST
Modified files:
tuhopuu3/source/blender/include BIF_toolbox.h
Log:
Argh! Forgot this file. That's what I get for committing and
then going out for the night. Now it all should compile properly.
Silly me.
Download here:
http://www.savefile.com/files/1369198
Hope this works..
kidb
Re: Tuhopuu3 / Windows (2005/06/04) CygWin
Post by kidb »
or here
http://blendertestbuilds.kidb.de/index. ... cygwin.zip
Bellorum wrote: Hope this works..
me too.
Bellorum
Post by Bellorum »
venomgfx
Post by venomgfx »
Can't download here.. :(
or it fails when downloading.. i'm on 56k by the way...
Bellorum
Post by Bellorum »
venomgfx wrote:Can't download here.. :(
Loading fine here :/ Did you try the alternative download link Kidb provided?
poutsa
Post by poutsa »
The TOOL BAR IS AMAAAZING! Great Job!
thanks for this Tuhopuu Build!
Vassilios Boucer
cekuhnen
Post by cekuhnen »
the toolbar is quite interesting!
but i do not know if ity is that usefull.
i mean i find it already very flexible to access blender tools.
for sure i appreciate that values like for subdiv etc. dont have to
be entered always again.
i wil have to work with the toolbar more. i can imagine when you
repeat jobs again and again it might be good.
but anyway good work.
claas
Pierre-Luc_Auclair
Post by Pierre-Luc_Auclair »
Very unstable, crashes constantly.
I get:The instruction at "0x77f82e87" referenced memory at "0x00000008". The memory could not be read.
Happens in edit mode (I think). Can't replicate the error constantly (not to my knowledge at least).
FourMadMen
Post by FourMadMen »
The toolbar is very nice! And greatly appreciated.
Bellorum
Post by Bellorum »
Updated build. See first post.
Delta
Post by Delta »
(im using the 6-4 build from kibd...)
the toolbar looks nice, from what ive seen....
but i could only get about 2 minutes of fooling around with it before Tuhopuu crashed...
and now Tuhopuu cant even load without crashing
do i need the environment files for this build or can i just hijack the ones from 2.37?
Regards,
~Delta
Bellorum
Post by Bellorum »
Delta wrote:(im using the 6-4 build from kibd...)
Regards,
~Delta
Strange. I have no problems at all. Have you tried downloading the latest build? All required files are included in the zip.
dotblend
Post by dotblend »
can someone please post a new yafraybuild. (win 32bit) PLEASE!!!
Bellorum
Post by Bellorum »
dotblend wrote:can someone please post a new yafraybuild. (win 32bit) PLEASE!!!
http://lynx.aspect-design.de/yafray/yaf ... _setup.exe
logan666
Post by logan666 »
I get an import site failed in the console at start up.
I've also got Blender 2.37 up and running with python 2.35 with no prob.
