Bf-Blender / Linux (2005-8-28) with envelopes and IK
JoOngle
Post by JoOngle »
This is the latest CVS Bf-Blender for use with an OpenGL enabled Linux system.
Compiled 28 August at 0200 hours Copenhagen time.
http://www.hamsterking.com/blender/file ... 8-8.tar.gz
This compile has the following Physics engines: Sumo
This compile also features new IK by Brecht Van Lommel
Developers log files:http://projects.blender.org/pipermail/b ... /date.html
Keep testing and report bugs in the bugtracker!
UglyMike
Post by UglyMike »
Works great here, thanks!!
OTO
Post by OTO »
Hello
and thank you for the Linux build!
At the moment works fine!
Keep testing
Bye
JoOngle
Post by JoOngle »
My pleasure,
Keep testing and reporting bugs to the developers in the bugtracker.
malefico
Post by malefico »
I'm getting segfaults using L to select bones in edit mode, anyone else is getting the same ?(so I'll report it)
JoOngle
Post by JoOngle »
malefico:
I'm trying and trying and can't quite reproduce your problems. Everything seems fine here
so far.
BTW: I made an update 23:00 yesterday, try downloading it again if you downloaded
the "24" version earlier than 23:00 yesterday! It might have been a bugfix.
Anyway - I'll probably update this thread with even another version either
today or another day depending on the changes in Blender.
Stay tuned - this thread will be updated with new versions as long as I have the
time to do so.
orion119net
Post by orion119net »
thanks for the build!
ive been playing aroud with a model, and i noticed that when i select 2 or more bones, rotate them, and hit alt-r, nothing happens. same thing happens with alt-g.
does this happen to anyone else?
malefico
Post by malefico »
Hi, I've compiled it myself today and yup, it still crashes. I do this, create an armature, select a couple of bones (clicking in the middle of the bone, not the tips), then press L with mouse over armature -> Segfault.
Regards
malefico.
EDIT: Funny, it doesn't happen all the time, I'll keep testing to figure out WHEN exactly happens...
JoOngle
Post by JoOngle »
I've gotta hand it to the developers,
those new loopcut tools rule!
For those who don't know what I'm talking about, try these things in the version of
16-8-2005:
1) Select Ctrl + R for loopcut
2) Scroll with the scrollwheel to select number of loops to cut (or use + & - keys)
3) Press "S" for smoothing cuts if you want that...
Sweeet....
And the new & improved (1000 times over again and changing all the time) edgeslide
is quite useful too (see it in the Ctrl E menu for edge specials)
The edgeloop delete has "hemesh" qualities...here you can delete edges and keep the
faces :) No need to do "f" after deleting an edge (or a row of edges/loop) after
this...niiiice.
OTO
Post by OTO »
Hello
the "create vertex groups from closest bones" don't work?!
gaiamuse
Post by gaiamuse »
OTO wrote:Hello
I am having the same problem with the windows build 19.08.05 with envelopes. This does not occur with the 02.08.05 windows build.
I noticed that there is a new armature modifier. What does that do?
gaiamuse
pamtango
Cannot run program
Post by pamtango »
I get this error when I try to run the program from within the folder where I have Blender 2.37. It doesn't run at all when outside this folder.
/home/pam/Desktop/blender-2.37a-linux-glibc2.2.5-i386-static/blender-20-8: error while loading shared libraries: libpng.so.3: cannot open shared object file: No such file or directory
Sorry if this is a basic question.
PamTango
popski
Post by popski »
Same error here:
Using Ubuntu, installed:
libpng10-0, libpng12-0, libpng12-dev :roll:
I don't like Blender, oh no, I love it! :D
-efbie-
Post by -efbie- »
well, guess what, you need libpng "3" :)
popski
Post by popski »
Did you eat clown cake or something?
