bf-Blender / Windows (2005/07/24)
Posted: Sun Jul 24, 2005 3:49 pm
A new build, Modifier stack is now a pleasure to work with, There is also some big changes, such as the removal of the posemode. There is a lot of rewrites going on, please test carefully.
Quoted for you theeth: *NOTE*: Some UI decision done in this commit will most likely be revised, all flame shall go in /dev/null. Constructive discussions of course welcomed.
Builded with MSVC 7.1 on windows
Releant feature:
-Bugfixes
-Changed the shortcut of Shear in objectmode to CTRL + ALT + SHIFT + S
-modifiers in editmode are back (which means auto-mirror in edit mode works now) although still not finished.
-Killed silly modal PoseMode mode!
-Lasso select in posemode and editmode of armature.
-Added option to the IK buttons, to have it use the 'tip'
-Hotkey CTRL+I: add IK
-Hotkey ALT+I: clears IK
-Hotkey ALT+C: clears Constraints
Commit:
-desoto
Log:
Fix for bug #2766: Shear shortcut broken
The problem is that the shear shortcut that was originally chosen was
eaten up by the shortcut to switch to the scale blezmo. Changed the
shortcut to CTRL + ALT + SHIFT + S which is painful but seeing as how
shear in object mode has limited use, I don't think it will cause any
real problems. I also updated the menu entry to match.
This was assigned to Martin but he's busy so I did it... and if I did it
wrong... blame him for not fixing it sooner
-zuster
Log:
- added data arguments to deformer modifiers, in case someone wants
to write one that is based on geometry (and not just vertex position)
- added editmode versions of modifier deform/apply calls and flag
to tag modifiers that support editmode
- added isFinalCalc param to applyModifier, basically a switch to let
subsurf know if it is calc'ng orco or not (so it can deal with cache
appropriately). This is kinda hacky and perhaps I can come up with
a better solution (its also a waste to do a complete subdivide just
to get vertex locations).
- changed ccgsubsurf to not preallocate hash's to be approximately correct
size... this was probably not a big performance savings but means that
the order of faces returned by the iterator can vary after the first
call, this messes up orco calculation so dropped for time being.
- minor bug fix, meshes with only key didn't get vertex normals correctly
calc'd
- updated editmesh derivedmesh to support auxiliary locations
- changed mesh_calc_modifiers to alloc deformVerts on demand
- added editmesh_calc_modifiers for calculating editmesh cage and final
derivedmesh's
- bug fix, update shadedisplist to always calc colors (even if totvert==0)
- changed load_editMesh and make_edge to build me->medge even if totedge==0
(incremental subsurf checks this)
todo: add drawFacesTex for ccgderivedmesh
So, modifiers in editmode are back (which means auto-mirror
in edit mode works now) although still not finished. Currently
no cage is computed, the cage is always the base mesh (in
other words, Optimal edge style editing is off), and the final
mesh currently includes all modifiers that work in edit mode
(including lattice and curve). At some point there will be toggles
for which modifiers affect the final/cage editmode derivedmesh's.
Also, very nice new feature is that incremental subsurf in object
mode returns a ccgderivedmesh object instead of copying to a new
displistmesh. This can make a *huge* speed difference, and is very
nice for working with deformed armatures (esp. with only small
per frame changes).
Log:
- bug fix, old files with me->subdiv==0 crashed, fix to make sure they
don't crash and also changed patch to properly init SubsurfModifierData
-ton
Log:
Motion blur didn't work for Object Ipos (rest worked OK), so simple
fix.
Also removed the ugly old 'update for newframe' from renderwin.c, the
new call scene_update_for_newframe() does it much friendlier.
Log:
Error in drawing of new armature options;
bglPolygonOffset(0) was accidentally called without it being set before,
causing window matrix to go weird.
-zuster
Log:
- fix a bug with softbody, verts were copied out of order (meant
history was lost... I think, dunno this code well.)
- commented out code to do merging of quad with 3 verts shared in
mirror mode... didnt seem worth the effort and mesh still wasnt
perfect afterwards
- bug fix, indices for triangles were not swapped correctly in
mirror, could lead to crash with subsurf in editmode
-guitargeek
Log:
Added code in loopcut to undo cut if edgeslide was cancelled. (For you Chris!)
Also Added some code for UV's in subdivide. This is close, but still is not perfect
-ton
Log:
- PoseMode now is a state Armature Objects can be in. So, while in PoseMode
for an Armature, you can just select another Object or Armature.
- The old PoseMode options (transform, insert keys etc) are accessible
with making the Armature Object 'active' (and have object in PoseMode).
- At this moment no multiple Poses can be transformed/edited at the same
time.
- The old hotkey CTRL+TAB, and view3d header menu, still work to set an
Object's PoseMode
It was quite a lot recode, so tests & reports are welcome.
Oh, as a bonus I added Lasso Select for Bones in PoseMode! It selects using
only the line between root and tip of the Bone.
Log:
- Armature editmode now supports lasso. Please be aware that in editmode,
armatures actually only consists of points, flushing bone selection
based on points that are selected.
Renamed the "Lines" drawmode for bones to "Sticks". Thanks Basse!
- Fix; crash in selecting in editmode armature (commit 1 hour ago)
- Fix; in editmode, bones didn't transform (same commit)
- Fix; in drawmode "Sticks", names could go weird in editmode (commit
two days ago)
-theeth
Log:
Big Transform Manipulator Merge
This commit merges manipulator orientation selection back in "traditional" transform.
That's how it works:
- The dropdown in the 3D view header is always visible
- The orientation chosen will be used when choosing an axis with MMB and for the *second* key press of X,Y,Z
However, Local orientation doesn't use the one calculated by the manipulator. This is to ensure that multiple object local and armatures in pose still works as before.
- Alt-Space (to change the orientation) works during transform
New Transform orientation: View, using the view axis.
Fixes for the following bugs:
- Constraint projection code "jammed" if input vector was <0,0,0>, reported a couple of times on IRC. Thanks to Basse for the example file.
- Transform on texspace crashed on objects without texspace data (camera, lamp, ...). This was reported in tracker.
- Numinput with lock constraints didn't work correctly. Reported on elysiun
Probably some others that I'm forgetting
I also moved a couple of functions around in an attempt to make things clearer.
-ton
Log:
Armature-Pose IK goodies!
- Added option to the IK buttons, to have it use the 'tip' as end of the
IK chain. I never really understood this old convention (IK didn't work
on the Bone itself).
Old files still will read OK though. But I made the "To Tip" a default
when adding new IK constraints.
- Hotkey CTRL+I: add IK, with option to have it adding an Empty target,
or use a selected Bone as target. With the new non-modal PoseMode, it
gives instant access to playing with the IK chain.
- Hotkey ALT+I: clears IK, on all selected Bones
- Hotkey ALT+C: clears Constraints on all selected Bones (incl IK)
A new build is available
Releant feature:
-Bugfixes
Commit:
-desoto
Log:
-zuster
Log:
calc'd
derivedmesh's
per frame changes).
Log:
-ton
Log:
fix.
Log:
-zuster
Log:
perfect afterwards
-guitargeek
Log:
-ton
Log:
time.
Object's PoseMode
Log:
two days ago)
-theeth
Log:
-ton
Log:
