Win: Builded with MSVC 7.1
Linux: Builded with gcc 3.3.6 glibc 2.3.5
Relevant Feature:
-Bugfixes
-added apply button for individual modifiers
-added wave modifier & removed old wave effect
-added decimate modifier & removed old decimate interface
-Added PoseMode CTRL+C copy menu
-Game engine work: bullet
-Wkey menu, "Flip Left/Right Names".
-in PoseMode/EditMode draws name of active Bone
-Added the new Armature/PoseMode options in View3D pulldowns.
-Compressed files are back!
-Introduced Bone type "Hinge".
-PageUpKey moves action up one row ( shift == move to top )
-PageDownKey moves action down one row ( shift == move to bottom )
-multiple selections allowed in action windows.
-BPY: shader data access to Blender.Material.
-Scripts updated: paths import, tex2uvbaker, obj exporter.
-BPY: support for Font, Curve, Surface and Meta Objects in Blender.NMesh.GetRawFromObject
Commit:
-ton
Log:
NLA strip option "Add" accidentally also added constraint ipo values.
Result was characters going bezerk! By definition, pose blending now only
adds loc/rot/size, not constraint strength values.
Log:
Bug fix #2856
Changing 'active material' in Editing Buttons didn't update preview in
in Material Buttons.
Log:
When entering editmode on Armature, the Pose now defaults to a correct
restposition, also for deform and bone childs.
Log:
Regression file teapot.blend didn't render... this due to a hack removal of
a month ago (trying to cope with vertexcolor 'paint' and 'light'.)
Forgot to add the correct check for calculaing UV texture coords, needed to
have vertexcolor 'paint' working.
Log:
Little issues, combined commit!
- Bug #2857: Spin didn't create nice consistant normals
- removed unnecessary call to where_is_object() in init-render phase.
- Added DAG_scene_sort() calls when objects were removed (join cases)
- When using texture fonts, the file window header didn't display OK
- Saving a file didn't set the 'wait cursor' anymore (oldie!)
-zuster
Log:
- fix some error handling in blend loader, correct error codes
were not always returned.
Log:
- added RNG abstract random object rng_{new/free/seed/get{Int,Double,Float}}
to avoid use of global generator. at the moment the renderer owns the
number generator and this is important for retaining render consistency.
-ton
Log:
- Dupliframes mball didn't work anymore (should be added to scene_update)
- restored nicer drawing for duplicator wireframe. Draws before selected,
so you can see the duplicated object better
-zuster
Log:
- removed internal functions from effect header
- made particle system generation use its own RNG object,
keeps it safe against varying calculation order in the renderer
Still a funny bug where having a material on a particle object
changes the particle locations (in renderer, not in interface...
bizarro)
Log:
- displacement fix, need to calc normals before displacing
Log:
- added apply button for individual modifiers
Log:
- added wave modifier & removed old wave effect
- added decimate modifier & removed old decimate interface
(currently lacks warning about destroying data, and there needs
to be a way for modifiers to return errors back to the interface)
- allow applyModifier to return NULL to indicate error
- unfortunately new decimate modifier means it does not know exact
number of faces in mesh (other modifiers may come before) and so
instead interface uses a percentage. if people need exact face
count slider then I will have to think of some hack to fit this
in. note that it does display the output face count so its possible
to tweak the pct to get what you want regardless.
- removed python Wave object
If you are bored now how much easier it is to implement something
like decimate as a modifier. Very few changes to interface, very
few entry points.
Log:
- bugfix, mirror modifier didn't copy deformed vertex cos for shared
verts
-ton
Log:
Added correct call to have curve paths calculated, when the anim system
discovers it wasn't done yet. Needs displist now, not calc-path.
Solves reported bug in regression file bowl.blend (camera didnt move) and
errors in NLA stride paths.
-guitargeek
Log:
Removed Vertloop Select and Faceloop select from toolbox
Log:
In Vertex Select Mode
CTRL-Alt-RMB = Faceloop Select
-ton
Log:
Added PoseMode CTRL+C copy menu. Does loc/rot/size and constraints.
Log:
Fix in outliner. Renaming PoseChannels didn't call the routine that checked
all bones, other poses, constraints, actions, etc.
Also: for clarity, brought back the display of both Armature Bones as
Pose Channels. Renaming either works, but you can notice the constraints
are on Pose, not Armature.
Little bug still; the order of drawing (pose, armature) sometimes flips,
don't know why yet. Tomorrow!
-zuster
Log:
- decimator modifier was giving wrong # of verts when a previous
modifier was active
-theeth
Log:
Image memory garbage collection wasn't working correctly due to a poorly constructed if clause (it was collecting only images marked as NO_COLLECT, which only happens with Python loaded images).
Another problem now is that the userpref values aren't correctly saved in .b.blend, they always reset to the default. Will look into that.
Log:
Image memory garbage collection:
clock seemed to work weird on some machine, switching to PIL_check_seconds_timer.
It's more in line with the rest of Blender anyway.
-erwin
Log:
- added debug line drawing in gameengine (handy for debugging physics problems)
- added #ifdef for a visual studio 8 crashing problems
- added scaling and tolerances to triangle meshes
-ton
Log:
Cleanup & goodies for rigging geeks!
- PoseMode: Wkey menu, "Flip Left/Right Names". On selected bones, it flips
the L/R tags in names, and calls the proper code to rename everything
that's related (constraint targets, bone-childs, etc).
- PoseMode: Shift+S snapmenu: snap cursor to selected now works
- Outliner: select bones now correctly sets 'active' flag for bones,
updating the UI as well.
Also made sure you cannot select hidden bones in outliner.
- 3DWindow: in PoseMode/EditMode draws name of active Bone too (with user
option "Draw active object name" set.
- Added the new Armature/PoseMode options in View3D pulldowns.
Cleanup:
- moved Pose code from editaction.c to poseobject.c
- removed BSE_editaction.h and BSE_editaction_types.h, moved contents of
it to BIF_editaction.h. One include per C file should be fine.
I know the src/ structure would require more elaborated includes, but
we don't have that now...
-guitargeek
Log:
Added Name flip for
_L
_l
_R
_r
Also added if suffix == 001, do not re-add suffix. So allows the following procedure
bone named Bone_R is copied, becomes Bone_R.001
Bone_R.001 is Flipped, becomes Bone_L
Currently only works for 001, could be extended later
-ton
Log:
Bug fix #2870
Wire material doesn't work with raytrace, but the wire faces were still
trace-able, giving weird results.
Now the wire faces are excluded from the octree.
Log:
Patch provided by Shaul Kedem: Compressed files are back!
He even made a nice doc in wiki:
http://wiki.blender.org/bin/view.pl/Blenderdev/Blendgz
Usage: set the option "Compress File" in the main "File" pulldown menu.
This setting is a user-def, meaning it is not changed on reading files.
If you want it default, save it with CTRL+U.
The longest debate went over the file naming convention. Shaul started
with .blend.gz files, which gave issues in Blender because of the code
hanging out everywhere that detects blender files, and that appends the
.blend extension if needed.
Daniel Dunbar proposed to just save it as .blend, and not bother users
with such details. This is indeed the most elegant solution, with as
only drawback that old Blender executables cannot read it.
This drawback isn't very relevant at the moment, since we're heading
towards a release that isn't upward compatible anyway... the recode
going on on Meshes, Modfiers, Armatures, Poses, Actions, NLA already
have upward compatibility issues.
We might check - during the next month(s) - on a builtin system to
warn users in the future when we change things that make a file risky
to read in an older release.
-zuster
Log:
- update storage.c to use standard time codes (should fix issue
with MSVS
- broke mesh_create_shadedColors out of shadeDispList, used to
build vertex colors for mesh in vpaint as well (also fixed
bug where they were not initialized correctly for subsurfs)
- added modifier_copyData and modifier_findByType functions
- change editmode modifiers to only calculate if Realtime and
Editmode bits are both set, makes more sense for copying
modifiers
- update object_copy to correctly copy modifiers
- removed duplicate redefinition of ME_ attributes in python,
this is a horrible idea, why was it done in the first place?
- update armature auto vertex group code to check for subsurf
in modifier stack
- fixed flip_subdivision to work with move to modifier stack
- added copymenu_modifiers, can copy all modifiers or just
data from first modifier of a certain type (not sure how
to deal with multiple modifiers of same type... not
a big issue though I think)
-ton
Log:
Nice time saver for Armatures: Introduced Bone type "Hinge", which doesn't
inherit pose rotation/scale from its parent pose-channel.
Button is available in Editing Buttons for PoseMode as well as EditMode.
Aim is to reduce overhead of Constraint usage (copy location).
(in object.c I removed old code for IK)
Log:
Bugfix #2875
Removed old code that was used when the global undo still saved files. It
was restoring pointers in the UI based on names, which gave confusing
results when loading the quit.blend file (actually undobuffer).
Instead it should treat the quit.blend same as "Load without UI" option.
Log:
Forgot to add correct offset for drawing multiple PoseChannel buttons,
editbutton context. Thanks Ztonzy!
-guitargeek
Log:
A Small change on Edgeslide while I try to come up with a better mouse interaction.
Move mouse - 5%
SHIFT modifier - 1%
CTRL modifier - 10%
-erwin
Log:
added physics-debugging
didn't check every single file, so might have broken some gameengine stuff, will fix it this weekend!
-guitargeek
Log:
Another UV tweak for subdivide, It seems to work better now, still not perfect
Log:
Flush Edge selection down to verts in subdivide if you are in Vertex select mode
-intrr
Log:
Fixing (hopefully) a stupid issue with rendering text objects:
cu->curinfo.mat_nr appearently didn't get initialized to 0 when creating
a new curve / text object, thus assigning random material indices to
characters, which crashed when rendering.
I'm still not sure if this was the actual issue, though I'd hope so
For old files that crash on rendering, just enter editmode on EACH text
object, select all text, and assign a material to it.
I hope this fixes.
-guitargeek
Log:
Edgeslide Mouse Movement Fix
Edgeslide movement is now controlled by a line drawn between the endpoints of the 2 control rail edges. Edgeslide will
try to pick a control rail pair (will color green ATM) if you don't like the edge it picked, use the mouse wheel up to change it.
have to code mouse wheel down to go other direction still. Just ran out of time ATM and wanted to get this in for movement testing.
movement is in 1% per edge (so 1% out of -1 to 1)
CTRL makes it 10%
SHIFT makes it .1%
Se what you think and give me some feedback on functionality
-erwin
Log:
more physics work, tuning parameters, hooking up friction etc.
-guitargeek
Log:
For edgeslide control rail there are 2 options:
Scroll Up/Down and Left/Right arrow key will cycle through the control edges in either direction.
I got rid of SHIFT for the time being.
-bjornmose
Log:
yo bassam, here it is
Action editor UI tweaking:
-guitargeek
Log:
Adding a little idling to Edgeslide loop,
Log:
Some more loop fixing, this time in loopcut
-ianwill
Log:
Scripts updated:
- Jean-Michel Soler: 1) paths import -- ai module; 2) tex2uvbaker;
- Campbell Barton: obj exporter.
BPython:
- Campbell also provided a patch (+docs) to add shader data access to Blender.Material.
Again, thanks guys and sorry for the long delay.
-desoto
Log:
Work for fix of #2256 "something weird with some buttons":
NUMSLI buttons with retval of 0 can be used to trigger other buttons. Not
sure if this is best course of action but will investigate more. Until then
buttons_shading.c is clear of NUMSLI buttons with retval of 0 and now use
B_DIFF as retval argument (which happens to be 1).
-theeth
Log:
This patches adds support for Font, Curve, Surface and Meta Objects in
Blender.NMesh.GetRawFromObject through a displist conversion method as used by
Blender when converting them in the UI.
Notes: Objects with only edges (3D curves/polyline without bevel) do not have
normals, so they are all initialised to (1, 0, 0) on conversion
Converting from meta objects only work on the "mother ball". That is,
the object with the lower base name.
Example: "meta" for all the "meta.*" objects.
Meshes extracted from curve based objects (Font/2D filled curves)
contain both the filled surfaces and the outlines of the shapes.
Materials are taken from the object's material list. Material handling
in NMesh is incorrect anyway, as it always uses the materials from the
mesh, ignoring the setting in ob->colbits.
This patch also makes the include order a little clearer.
A couple of warnings have been fixed by using better types:
- Using char instead of short when parsing color values.
The "constructor" expects and uses char anyway.
- Explicit casting to short when storing normals back in mvert.
- Changing constant doubles to floats with "f" to make compiler happy.
The only warning left regards NMFace.flag which is stored as a short but is
used to fill in TFace.flag which is a char. I didn't want to change the
object's structure so I left it like that. I didn't add an explicit cast when
putting it back in TFace so that the warning can remind us that there might be
something to change there.
-theeth
Log:
BMFont didn't define correct character size for "Screen 15" font for TAB and NBSP.
Found out through ideasman's interactive console script.
-guitargeek
Log:
Make Loopcut in Faceselect mode able to enter Edgeslide and not get 'loop crosses itself' message. Still need to work on selection out of this condition
A new build is available
