Soc project: verse-blender Linux/Mac/Win (2005/09/1)
jiri
Post by jiri » Fri Aug 19, 2005 10:37 am
NEWS:
1) Changes of mesh geometry comming from other verse clients are visualised in object mode too.
2) You can try experimental undo in edit mode.
3) Shared objects have different color of object center.
4) it is possible to rename object node (when you rename nameof mesh object, then object node is renamed too and this change is sent to verse server)
5) Several bug fixes
You can find all testing builds as well documentation at:
http://wiki.blender.org/bin/view.pl/Ble ... derUserDoc
Read user documentation carefully and keep in mind, that only Mesh Object is supported (object transformation, edit mode actions).
Feel free to send me any commentary.
Jiri Hnidek
kakapo
Post by kakapo » Fri Aug 19, 2005 2:20 pm
it's great! :)
will there also be gimp and photoshop plugins? i would find verse extremely helpful for texture previewing without the hassle of continuously exporting / importing...
Caronte
Post by Caronte » Fri Aug 19, 2005 4:25 pm
I tested it with a friend and I'm surprised because I can see the changes he made to the object IN REAL-TIME :shock:
Awesome! ;)
Caronte.
http://www.nicodigital.com
mataii
Post by mataii » Mon Aug 22, 2005 5:10 pm
Yes :shock: ! I`ve tested too .. and I really like it :wink:
Caronte
Post by Caronte » Mon Aug 22, 2005 5:53 pm
Yes, see the update in realtime is very awesome ;)
[off_topic] Hi mataii !!
Glad to see you again.
Many of the spanish BlenderHeads are in www.3dpoder.com I hope to see you on this site ;)
[/off_topic]
Caronte.
ZanQdo
Post by ZanQdo » Mon Aug 22, 2005 9:09 pm
Yes, It`s awesome! What are the plans for the undo? It causes strange behavior when two users are editing the same mesh.
Edit. the wiki says:
TODO
* support for undo (object mode, edit mode, etc.)
* verse update and verse callback function in seperated thread (to get rid of terminated connections)
* Add support for 'verse edges' at least as internal data structure
* Pushing mesh geometry to verse server, when Object is in object mode
* Visualisation of shared object (different color of Object center)
* Better handling of verse sessions (reconnect, etc.)
* Visualisation of verse layers in Outliner
* Support for subsurf
* Vertex color
* Vertex weight
* UV
* Armatures, Bones
* RVK
* etc.
jiri
Post by jiri » Tue Aug 23, 2005 12:04 pm
Undo system isn't supported now. When you press "U" in edit mode, then you can expect strange behavior. Undo (ctrl-z) doesn't work in object mode too. What problems do you have, when two users edit same object? Can you describe it exactly?
Jiri
mataii
Post by mataii » Tue Aug 23, 2005 6:00 pm
jiri wrote:Undo system isn't supported now. When you press "U" in edit mode, then you can expect strange behavior. Undo (ctrl-z) doesn't work in object mode too. What problems do you have, when two users edit same object? Can you describe it exactly?
Jiri
well, I think I cant describe it. because zanqdo and me were trying the build..
we were trying with the build, making extrusions etc, everything seems to be ok untill I pressed Ctrl+Z (Undo) in edit mode, and then the object go back to the start, almost every extrusion dissapear :?
that`s what i remember :roll: , do you remember anything else, zanqdo?
jiri
Post by jiri » Wed Aug 24, 2005 8:34 pm
Yes, I know about this bug. Undo (pressing "u" or "ctrl-z") as well redo (pressing "shift-u" or "ctrl-y") works, but bindings between verse server and local data are destroyed and you can expect strange behavior. Is it clear now?
Implementation of support for undo is on my todo list!
Jiri
jiri
Post by jiri » Fri Sep 02, 2005 12:37 am
I merged two threads (win and lin/mac) to this one thread and I made it sticky.
Jiri
Sutabi
Post by Sutabi » Fri Sep 02, 2005 1:37 am
@_@...
i THINK i AM gonna cry.... The make uses of this alone!!!! SMC's, Modeling tutorials, etc.... I wish ... i wish.... [sobs] its so beutiful!
ZanQdo
Post by ZanQdo » Fri Sep 02, 2005 5:44 am
Hi, thanks for the update, new features look really cool :D
The hosts you are using are slow, so I have mirrored your files at my builds gallery, hope you dont mind :P
direct links:
Windows Build
OSX Build
Linux Build
:-) Hosting for your test builds:
GraphicAll.org
jiri
Post by jiri » Fri Sep 02, 2005 12:41 pm
thanks for your hosting of bleder-verse binaries.
I put my binaries at my old sites, because I can create and upload my linux binaries with one simple bash script ;-).
Jiri
kidb
Post by kidb » Fri Sep 02, 2005 1:09 pm
jiri wrote:Hi,
Jiri
If anyone is interested:
http://www.blender.org/forum/viewtopic.php?t=6821
ftp access for upload possible.
nam
Post by nam » Fri Sep 02, 2005 5:41 pm
i was just messing around with this verse version for the first time, and i have to say, this is some cool sheets, of paper...works pretty well i must say. i can totally see this being used to give some live online tutorials...or other stuff...which is cool...
