bf-Blender / Windows (21/08/05) without game engine
lguillaume
Post by lguillaume »
Hello, there is 2 functions to test and put feedback:
Log (Ton):
New feature; User definable Clipping Planes.
Press ALT+B in 3d window, draw a rect, and it becomes a clipping
volume of 4 planes. You then can rotate the view anyway you like.
Works for each 3d window individually.
Disable it with another ALT+B press.
Commit is huge because it had to change all selection code as well.
The user-clipping planes are in 'eye space', the other clipping
happens in projected 'viewport space'.
Nice to notice is that the 'x=3200' convention (to denote a coordinate
is clipped) now is a define. Define value is still a number though... but
we now can get up to screens of 12000 pixels without issues!
Known issue; here it refuses to draw the 'object centers' or Lamp icons
within the clipping region. Can't find any reason for it... however, we
might move to non-pixmaps for it anyway.
Testing might reveil numerous issues, will be standby for it.
Curious? Check this http://www.blender.org/bf/rt4.jpg
log (zundar):
- added mesh_strip_loose_faces, works in conjunction with make_edges
to get rid of faces with MFace.v3==0
- change all Mesh's to have ->medge now. This is forced by make_edges
on readfile, and in the various exotic important routines, and on
conversion back in python.
- make python NMesh structure always have medges now (needs testing)
- with above two changes it is guarenteed that mf->v3 is never ==0
in main blender code (i.e., all MFace's are actually triangles
or quads) and so I went through and removed all the historic tests
to deal with MFace.v3==0. Equals lots of deleting, I am in heaven!
- removed MEdge edcode flag, no longer needed
- added experimental replacement for edge flag system
Still are some inconsistencies in FACESELECT mode edge drawing to
be ironed out.
NOTE: This commit adds an experimental edge flag calc system, based
on 10-seconds-of-thought algorithm by yours truly. Would appreciate
feedback on how this system works, esp compared to old one and esp
on complex or interesting models.
To Use: New system is enabled by setting G.rt to a value between
1 and 1000 (Value of 0 uses old system). Value 1000 is reserved for
"auto" edge, which is more or less identical to old system but also
makes sure that at least 10% of edges are drawn (solves errors for
super subdivided meshes). Values between 1 and 999 act as percent
(out of 1000) of edges that should be drawn, starting with "most
interesting" edges first. Please try it and comment!
zip release (2090 ko): http://lguillaume.suidzer0.org/bin/blender210805.zip
7zip release (1622 ko) : http://lguillaume.suidzer0.org/bin/blender210805.7z
Zsolt
Post by Zsolt »
The clipping planes are a very useful feature! However, I can't select anything inside editmode, only in object mode. Other things, like transforms, etc, work.
About the edge drawing: interesting feature, it does select the more interesting edges, but when I enter and leave edit mode, the edges that are drawn changes every time, sometimes these edges are drawn, sometimes others.
gaiamuse
Post by gaiamuse »
Hi lguillaume,
I cannot parent the mesh to armature using the armature option "use to closest bone" in the last two builds, 19.08.05 and 21.08.05.
I just checked with the 13.08.05 build and I can get this to work.
Also your builds have been tested using the other files included in Gabio's 02.08.05 build if that's any help.
gaiamuse
