nightly bf-blender build for OSX **Latest (02 Nov 2005)**
I will be maintaining the nightly build for OS X here:
http://blendertestbuilds.de/index.php?d ... SX/BrianH/
Compiled on OS X 10.4.2 Tiger and Python 2.4 is required. You can get Python 2.4 here:
http://undefined.org/python/
and the Tiger Patch (if needed) here:
http://pythonmac.org/packages/TigerPython24Fix-r2.zip
Tuhopuu3 build finished, I'll keep it uptodate as well as the rest. Enjoy.
To get it to launch, I had to change permissions on the executable. Just right-click and open package contents and go to contents/macos/blender. Open a terminal and type chmod 755 and drag in the file called blender and hit return. It should launch after that.
Thanks for the builds blueGecko, I was using an old CVS version and the rig from project orange wasn't working but it does with the latest build.
[edit] However, it's crashing when I try to open my blend files made using one of Lukep's builds, which was an older CVS. I get an update_pose_constraint_flags error from crt.c when reading the files:
0 org.blenderfoundation.blender 0x0029ecec update_pose_constraint_flags + 232 (crt.c:355)
1 org.blenderfoundation.blender 0x002cfe38 do_versions + 10860 (crt.c:355)
2 org.blenderfoundation.blender 0x002d2fb0 blo_read_file_internal + 596 (crt.c:355)
3 org.blenderfoundation.blender 0x002d6ac0 BLO_read_from_file + 60 (crt.c:355)
4 org.blenderfoundation.blender 0x002612b8 BKE_read_file + 92 (crt.c:355)
5 org.blenderfoundation.blender 0x00004d9c BIF_read_file + 56 (crt.c:355)
6 org.blenderfoundation.blender 0x00061dbc filesel_execute + 780 (crt.c:355)
7 org.blenderfoundation.blender 0x00064930 winqreadfilespace + 4264 (crt.c:355)
8 org.blenderfoundation.blender 0x0000c354 screenmain + 2768 (crt.c:355)
9 org.blenderfoundation.blender 0x000048e4 main + 2596 (crt.c:355)
10 org.blenderfoundation.blender 0x000033bc _start + 348 (crt.c:272)
11 org.blenderfoundation.blender 0x0000325c start + 60
I managed to open it in 2.37 and save the file again and it opened with all the UVs and stuff intact. Phew. This is why I didn't use CVS stuff before. It's also why I like the security of an ascii scene file, which Blender still doesn't have.
There seems to be a bug with this CVS version in that follow path constraints don't work properly. If you parent an object to a path, the constraint doesn't appear in the constraints panel although the constraint works.
If you constrain a bone to a path, the constraint appears but it doesn't work - the bone doesn't move along the path.
9-30-2005 Build
I was able to build the CVS source from 9-30-2005:
http://boswellian.spymac.com/files/bf-b ... 0-9-05.zip
I also built a version with the particle patch which supports guides:
http://boswellian.spymac.com/files/bf-b ... epatch.zip
They were both built with OS X 10.3.9, python 2.4
The fix for the executable was still needed but it crashes when launching because the binary is bad. Lol, if you open the binary up in a hex editor, it's just full of URLs. It looks like the developer's browsing history or something. I tried to look for any porno sites he had been visiting
. Mostly it's just project orange and things. There's nothing you can do to run this I'm afraid, you'll just have to wait for an update.
Here is the fix:
http://bchynds.com/index.php?option=com ... 3&id=12#12
I am sorry for the problems, it's under investigation.
