Soc project : fluid, OS X build 08/29/05
lukep
Post by lukep » Tue Aug 30, 2005 12:08 am
fluid simulator build for Os X : http://jlp.nerim.net/dev/fluid-blender-050829.zip
NOTE : need python 2.4 that you will find on www.python.org
An older build (same as previous) for those which have only the system python :
python 2.3 build : http://jlp.nerim.net/dev/fluid-blender-python2-3.zip
n_t : to get console output on Os X, you only need to launch the application found in utilities named : console !
n_t
Post by n_t » Tue Aug 30, 2005 2:06 pm
cool, it seems to work, thanks! and this console app is quite useful :)
osxrules
Post by osxrules » Sat Sep 03, 2005 10:02 pm
Thanks for the build Lukep but I can't find the edge loop select and face loop select. The hotkeys (alt-B, shift-R) don't work either.
TroutMaskReplica
Post by TroutMaskReplica » Wed Sep 07, 2005 5:09 pm
blender quits when i hit the bake button after following this tutorial: http://wiki.blender.org/bin/view.pl/Ble ... dTutorial1
i'm using the python 2.3 build
console output:
Blender quit
Using Python version 2.3
DEBUG object name=OBCamera, type=11 ...
DEBUG object name=OBCube.001, type=1 ...
Writing GZ_BOBJ '/Users/myname/Desktop/Fluid Sim/multi pusher2.blend_OBCube_cfgdata_OBCube.001.bobj.gz' ... DEBUG object name=OBLamp, type=10 ...
DEBUG object name=OBCube, type=1 ...
fluidsimBake::msg: Wrote multi pusher2.blend_OBCube.cfg
Running El'Beem from Blender with file '/Users/myname/Desktop/Fluid Sim/multi pusher2.blend_OBCube.cfg' ...
Current token: DT_INTEGER
Config Parse Error at Line 54: syntax error
DEBUG object name=OBSphere, type=1 ...
Writing GZ_BOBJ '/Users/myname/Desktop/Fluid Sim/test1.blend_OBCube_cfgdata_OBSphere.bobj.gz' ... fluidsimBake::msg: Wrote test1.blend_OBCube.cfg
Running El'Beem from Blender with file '/Users/myname/Desktop/Fluid Sim/test1.blend_OBCube.cfg' ...
edit: removed my real name from the log file.
lukep
Post by lukep » Wed Sep 07, 2005 6:49 pm
TroutMaskReplica wrote:blender quits when i hit the bake button after following this tutorial: http://wiki.blender.org/bin/view.pl/Ble ... dTutorial1
the older build had some quirks.
Also there is a space in your filename. that may be also a cause
TroutMaskReplica
Post by TroutMaskReplica » Wed Sep 07, 2005 6:59 pm
i've installed python 2.4 and downloaded the new version. seems to work now.
i won't officially bother the developer with this bug since it's a deprecated version anyway.
cheers.
Trevj
Post by Trevj » Mon Sep 12, 2005 5:43 pm
My blender also crashes when I hit "Bake" You mentioned that the older biuld may be buggy... is there a link to the latest OSX biuld? I'd love to play around with the fliud sim a bit.
-Trev
