bf-Blender / Windows (2005/09/12) patch Fluid & Particle
TorQ
Post by TorQ » Thu Sep 15, 2005 8:22 pm
hmm. Don't know why I didn't see that earlier. Where then do I set the amount of smoothing? The old version would ask you when you finalized the cut.
fakeplasticdreams
Toon Bug
Post by fakeplasticdreams » Thu Sep 15, 2005 11:08 pm
Not sure if this is the best place for this, but there is a bug in the toon shader in this build.
It created jagged edges on the boundary of the shaded are on object. It was Suzanne with subsurf 2 and setsmooth on.
lguillaume
Re: Toon Bug
Post by lguillaume » Thu Sep 15, 2005 11:42 pm
fakeplasticdreams wrote:Not sure if this is the best place for this, but there is a bug in the toon shader in this build.
Can you post image or you parameters to try, I have recent build
ElBarto
Post by ElBarto » Fri Sep 16, 2005 3:57 pm
Here is a small proposal for the Effect panel, it is far from nice but looks clearer then the actual one (is more uniform to familar thing too):
Karamba!
Bart.
http://www.area42.de/
Blender Feature Proposal:
http://www.neeneenee.de/blender/features/
fakeplasticdreams
Re: Toon Bug
Post by fakeplasticdreams » Fri Sep 16, 2005 9:43 pm
Sorry, a little mistep for me. :oops: It isn't only with this build that I am having problems. It is with 2.37a as well. I just didn't use the same parameters on 2.37a the first time as I did with this build.
It happens when I set the size of the diffuse toon shader up high. Even if I try to get rid of the shaded part by setting the size to the max it still shows up, and with jagged edges. Can anyone else reproduce this problem? I don't want to bug track it if it is only me.
Thanks
crsrma
Post by crsrma » Fri Sep 16, 2005 10:18 pm
fakeplasticdreams:
That's a fairly old issue, dating back to the inclusion of ray tracing lamps, I believe.
Not certain of the details, it's been quite a while. I think the only solution is to use lamps without ray traced shadows and/or disable ray tracing in the render panel altogether.
Another option is to disable the Shadow option in the shading panel; the object will still project a ray traced shadow, minus the surface artifacts, onto other objects if TraShadow is left enabled. The object will not cast shadows upon itself, however.
Toon_Scheur
Post by Toon_Scheur » Sat Sep 17, 2005 4:25 am
Blender crashes when I try to bake the fluid sim.
The settings were something like
start time= 0 end time=4
resolution=180
viscosity set on manual = 0.5 10E-5
Hardware:
Dual 3.06 Ghz Xeon
2 Gb ram
40 Gb Ultrawide SCSII
OS= Windows 2003
(yep, I snuk in the server room at work.. but this was a lazy server anyway ) :P
n_t
fluidsim crash
Post by n_t » Tue Sep 20, 2005 10:58 am
Toon_Scheur: the version currently in the cvs has a bug for resolutions above 128. I'll fix it once I have CVS access, sorry... Regards,
-> Nils
