Hello compilation with current CVS, nad many patch
All jahka patch : particle and explode
Patch from broken : New lamps/object center drawing, Patched from tuhopuu. This is incomplete, because it needs code to keep the center circles at a constant size. Hopefully someone (Ton?) can do this.
Patch from Nicholas Guttenberg (nichg) : Air resistance on the faces of a softbodies mesh rather than verts, and a force to preserve mesh volume
Patch from Richie : render from any view not only from camera:
How it works :
On the view3d header the last buttons enable to make a render of the view3D, now with the Richie's patch if you press Shift+click on the button you make a render of the current view with Blender internal render or yafray.
If you want to render an animation, press Ctrl+Shift+click on the button.
Richie continus to works on the patch to enable the render border for any view.
Use only DispWin, DispView does not work like He wants.
I don't put the log of CVS, is nearly the same as alpha 2.
Downloads:
7zip 2MB
zip 2.6MB
bf-Blender / Windows (2005/11/04) + many patch
Thank you very much for the build.
I think Richie's patch to render a 3Dview is very useful and it's good to see broken's work finds it's way into the official tree.
Reading the pre-release notes, I saw that particle guides won't make it into 2.40 - that's a pity. But maybe you can continue to integrate them into your CVS builds...
broken's work is only a patch for moment, and for Richie's patch, yes is very useful, he continus to work on it to enable render border, correct a problem when the camera is parenting , and put the renderer in the view3d.thoro wrote:Thank you very much for the build.
Do you have the same problems in the official alpha2? Perhaps the problems comes with a patch.bleen wrote:there seem to be a little problem with the sound...
when i play an animation there´s something like a click at the start/endpoint of the animation in my speakers (3d window).
i "disabled game sound" and "muted the mixdown"...no chance
hello!
it seems that my problem exist since 2.37a and before!
i listen to music (winamp) and play an animation (50frames).
you can hear a break after each loop of the animation (blender), sounds like vinyl crack
this break you can see in the waveform of the mp3 snippet.
maybe this might be bug for the bugtracker?!
http://151.189.20.30/crazydesign/probs/soundproblem.mp3
Hi, I am working with this build in a project, and I found the render-any-view feature doesn't work fine when the camera is tracking to an empty...
I test it in a new file, and it happens too. Maybe this is the trouble you talk about when say "parenting problem"?...
Thanks for the build, the render any view is cool!
jedihe
jedihe
