bf-Blender / Windows (2005/11/10) Tweak/Fullscreen/Merge
Bellorum
Post by Bellorum »
UPDATED 2005-11-10
Hi, guys!
Fullscreen and Tweak mode enabled.
Patched with Geoffrey Bantle's merge tools:
http://www.umsl.edu/~gcbq44/MergeTools/mergetools.html
Update:
Particle patch now merged with blender by Ton. Also, particle panels has been given a facelift. Look here for more info:
http://www.blender3d.org/cms/New_Partic ... 721.0.html
That's all you need to know :) Now, go download here:
http://www.graphicall.org/builds/builds ... show&id=44
mataii
Re: bf-Blender / Windows (2005/10/25) Tweak/Fullscreen/Merge
Post by mataii »
Nice tools ! :wink: , they are very usefull I like it :D
Caronte
Post by Caronte »
Yeah! Nice tools! ;)
BTW, (2005/10/25) ??? :?
Caronte.
http://www.nicodigital.com
Bellorum
Post by Bellorum »
Caronte wrote:Yeah! Nice tools! ;)
Oops :oops: 8)
zupermonkey
Post by zupermonkey »
Cool, shaded particles in the viewport!
pildanovak
Post by pildanovak »
great work...
pat
Post by pat »
i know it's a test build but try this: zoom in a good amount, then try to select (rmb) a vert (my testobject: a suze, subdiv multi: 2)
this should select a vert that's probably out of view, if not then you've not zoomed enough. i can provide a blend if needed
this does not work when in solid mode and view is clipped to front verts
if i don't answer (i'm not here very often) send pn or mail if you're interested in the blend
raygun11
Post by raygun11 »
I was testing new particles system ( i was modelling hairs )and I have one problem: how to control speed (lenght of strands) by vertex groups? ( I know how to define distibution by vertex groups).
on this site:http://www.blender3d.org/cms/New_Partic ... 721.0.html
Ton wrote: "To control speed of particles, or the length of a static particle strand, you can indicate to use a Vertex Group. The Vertex Group value will multiply with the existing starting speed.
The option is in the "Velocity" section of the Particle buttons. "
does it work in this build?
btw. new features are great :)
Bellorum
Post by Bellorum »
raygun11 wrote:The option is in the "Velocity" section of the Particle buttons. "
I believe Ton committed that a couple of minutes after this build was compiled:roll: I wasn't bout to make a new build just for that. I'm hoping for some new UI stuff before the next build.
cekuhnen
Post by cekuhnen »
hey
the particle system develops great! the shaded function with guides are great for making hair. i dont know how far animation will be a task, but for stills it seems to work amazingly fine.
different approach but still great result.
claas
Falgor
Post by Falgor »
Cool to see it going and going forward. I wonder if we see all these features in the actual release.
------------- EDITED & UPDATED, READ THIS-----------------
IF YOU ZOOM CLOSE TO THE OBJECT SO THAT ITS NOT COMPLETELY VISIBLE, YOU WILL GET SELECTION ERRORS IN EDIT MODE WITH VERTICES[
LetterRip
Post by LetterRip »
Falgor,
fullscreen, tweak, and merge - probably not. Everything else is already included in the code that will become the release.
LetterRip
tv
Post by tv »
but merge is so cool.
will at least the final released source be patchable by the merge patch?
Scott Wilkinson
Post by Scott Wilkinson »
The merge tools are excellent. What is the reason for not including them in an official release?
Bellorum
Post by Bellorum »
Scott Wilkinson wrote:The merge tools are excellent. What is the reason for not including them in an official release?
The patch is fairly new, and probably too close to official release for a proper review by Ton.
As for the other features -
Fullscreen - not going to be enabled in official builds in the state the code is now. Doesn't go well with ATI cards. Needs to be rewritten.
Tweak - Ton doesn't like it :roll:
