Bf-Blender 2.5 /Windows : build updated when needed.
jms
Post by jms »
mstram wrote:
jms wrote:Did you try the strand depth patch version ?
It was built on the 2006/08/19 CVS ...
Ok .. and I see it was updated today .. presumably from CVS ?? (+ your patch)
Mike
Yes ...
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
jms
Post by jms »
jms
Post by jms »
jms
Post by jms »
env
Post by env »
Hi Jms. The "texture baker" script doesn't work in last builts (seems since the modifier updates, but probably not related to).
jms
Post by jms »
In fact, no problem with modifier but with the setEuler function in the Object module which has been modified by khugues the 2006/08/14 18:01:28 :
object module modifs
jms
Post by jms »
env wrote:Hi Jms. The "texture baker" script doesn't work in last builts (seems since the modifier updates, but probably not related to).
You can replace the original script by this one :
http://jmsoler.free.fr/util/blenderfile ... e_baker.py
jms
Post by jms »
env
Post by env »
No, it doesn't work yet. "Mesh is not an object or it hasn't uv coordinates" message.
jms
Post by jms »
env wrote:No, it doesn't work yet. "Mesh is not an object or it hasn't uv coordinates" message.
Could you try yhis one :
http://jmsoler.free.fr/util/blenderfile ... ker_243.py
Do not forget to update the scripts menu . New name is "UV texture baker" .
(If it works, you will see a few improvements) .
env
Post by env »
"invalid syntax". :(
EDIT: deleted this part, I was wrong about the scripts not appearing. :mrgreen:
jms
Post by jms »
I downloaded and I loaded the script in the text editor of the current CVS compil', "as is" . I just did an "alt-p" and I did not see this error . Everything has worked correctly .
jms
12/09/2006 : 23h27
Post by jms »
env
Post by env »
You are right, Jms, it works great if loaded in the text editor and by Alt+P.
Earlier I tried it from the script manager window and from the scripts folder; in both cases the script appears in the menù but it doesn't work, the results are what I posted before.
BTW, very interesting. Any hint about those new features?
EnV
jms
Post by jms »
env wrote: Earlier I tried it from the script manager window and from the scripts folder; in both cases the script appears in the menù but it doesn't work, the results are what I posted before.
Try to replace the original name "UV_Texture_baker_243.py" by "tex2uvbaker.py" . I used it from the scripts menu without any problem ...
