Page 13 of 17
Posted: Mon Oct 30, 2006 4:47 pm
by jms
Thanks .
Posted: Tue Oct 31, 2006 12:25 pm
by huangshiren
:o
Snap to?Is transform snap item in object menu?
is it similar to move a object then hold Ctrl key?is there any other function?thanks!
sorry for my bad English! :roll:
Posted: Tue Oct 31, 2006 5:21 pm
by jms
huangshiren wrote::o
Under construction .
It seems to improve the old Magnetic Grid method . Look at the View Properties panel, there is a new slider : Divisions .
No worse than mine .
Posted: Sun Nov 12, 2006 10:37 pm
by Gimble
Thanks again jms for posting these builds :)
The November 12 compile complains of a missing file:
iconv.dll
though it is easy to find with a google search.
(most probably also have it if they search their hard drive)
Maybe this should be added to the blenderpack file
or is it just a compile issue?
Plus there seems to be a very bad bug using a
Wacom Intuos mouse (tablet) with the recent
CVS builds (which is not the case with version 2.42).
It completely ignores the tablet mouse driver, meaning
that you have to move the mouse across the entire tablet in
order to move across the Blender UI.
Anyone else experiencing this issue?
(Going to dl the latest mouse driver to see if that fixes it).
Posted: Mon Nov 13, 2006 6:35 am
by jms
Gimble wrote: Plus there seems to be a very bad bug using a
No problem with the little wacom graphire
Posted: Sun Nov 19, 2006 5:21 pm
by jms
For ffmpeg don't forget to download this package :
http://www.zoo-logique.org/3D.Blender/c ... _codec.zip
Posted: Tue Nov 21, 2006 8:18 pm
by ericsh6
I reported this bug:
[ #5269 ] texture paint causes Blender to freeze
Apparently this bug occurs in win32blender2011.zip build.
Here are the instructions on how to recreate the problem:
1) Open the attached blend file there are two texture images in the textures folder (face1.jpg and face2.jpg).
2) Blender should already be in texture paint mode so start painting. When the brush crosses one of the orange seem lines while painting then blender freezes.
The reason I want to have two UV images is so I can have more detail on the character's face so I can put detailed wrinkles. Otherwise I have to use a huge 2048 X 2048 or higher single image do texture my character.
http://markopuff.com/animations/texture_paint_crash.zip
Posted: Wed Nov 22, 2006 11:20 am
by jms
I checked your file with the lguillaume's compilation of the 11/20 and the problem does not appear . It seems that this is limited to my testbuild .
If the two pictures are "replaced" then everything works correctly but not if they are just reloaded .
Meta Objects
Posted: Wed Nov 22, 2006 7:34 pm
by Room335
Converting Meta objects to a mesh crashes Blender.
I'll report in in the tracker
Re: Meta Objects
Posted: Thu Nov 23, 2006 12:17 am
by jms
Room335 wrote:Converting Meta objects to a mesh crashes Blender.
The 2006/11/23 compilation works fine .
2005/11/23-2006/11/23 : this thread is one year old !
Posted: Thu Nov 23, 2006 1:47 pm
by jms
This thread is one year old !
Re: 2005/11/23-2006/11/23 : this thread is one year old !
Posted: Thu Nov 23, 2006 7:41 pm
by patricks
jms wrote:This thread is one year old !
congratulations JMS
Thank you for your dedication and good work :D 8) :!:
Greetings Patrick
Posted: Thu Nov 23, 2006 8:03 pm
by Hos
Thank you for this build! I have to ask though: why have you changed the default scene? It seems strange to have an initial scene with the povanim script in a text editor, which uses an orthographic camera, and which has a subdivided cube.
Chris
Posted: Fri Nov 24, 2006 8:46 am
by jms
Stats from Zoo/3D.Blender web site for 2005
November 2005 : 119 downloads
67 win32blender2311.zip
29 win32blender2411.zip
23 win32blender2711.7z
December 2005 : 1576 downloads
784 orangeblenderwin32.zip
106 win32blender1412.zip
137 win32tuhopuu31412.zip
83 win32blender1812.zip
107 orangeblenderwin32.7z
73 win32blender2012.zip
52 win32blender0712.zip
48 win32blender1912.zip
64 win32blender0712.7z
61 win32blender0312.zip
25 win32blender1312.zip
36 win32blender0612.zip
January 2006 : 1006 downloads
482 orangeblenderwin32.zip
124 win32blender0701.zip
97 win32blender1101.zip
69 win32blender1501.zip
67 win32blender0301.zip
57 win32blender2501.zip
53 win32blender3112.zip
45 win32blender2101.zip
37 win32blender0101.zip
26 win32blender2401.zip
9 win32blender3101.zip
February 2006 : 701 downloads
95 win32blender2402.zip
87 win32blender2502.zip
84 win32blender2202.zip
81 win32blender1502.zip
81 win32blender2102.zip
51 win32blender1202.zip
48 win32blender0802.zip
43 win32blender1102.zip
42 win32blender3101.zip
24 win32blender1802.zip
23 win32blender2002.zip
22 win32blender0402.zip
10 win32blender1402.zip
9 win32blender1902.zip
9 win32blender2302.zip
2 win32blender1002.zip
Posted: Fri Nov 24, 2006 12:35 pm
by jesterKing
Not 2006? :)
/Nathan
