Bf-Blender 2.5 /Windows : build updated when needed.
jms
Post by jms » Fri Nov 24, 2006 8:34 pm
As you see, 2006 is less impressive than 2005 .
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
jms
2006/11/26 build : no alt key in the text editor .
Post by jms » Mon Nov 27, 2006 8:55 am
jms
Post by jms » Sat Dec 02, 2006 7:12 pm
Attention : in the 12/02 version the dupliverts function only works with selected vertices (particles should work correctly) . I just tested these lines :
Code: Select all
static void vertex_duplilist(ListBase *lb, Scene *sce, Object *par)
MVert *vdata;
for(a=0; a<totvert; a++) {
    vdata = dm->getVertData(dm, a, CD_MVERT);
    if (vdata->flag & SELECT)
       { dm->getVertCo(dm, a, vec);
         dm->getVertNo(dm, a, no);
         vertex_dupli__mapFunc(&vdd, a, vec, no, NULL);
in anim.c
ericsh6
Post by ericsh6 » Sun Dec 10, 2006 3:23 am
I just install Ubuntu Linux on a i386 Pentium PC and then installed Blender CVS but Blender can't find the libalut.so.0 library. I installed OpenAl but the missing library still doesn't show up in the /usr/lib directory. Any ideas?
jms
Post by jms » Sun Dec 10, 2006 10:27 am
Sorry,
for the moment, I just make win32 builds .
jms
problem with the open exr version1.4 since yesterday, 14h00
Post by jms » Tue Jan 02, 2007 9:37 am
The new win32 zipped RC1 is available on the zoo/blender's directories .
toomuchcookies
Post by toomuchcookies » Sat Jan 06, 2007 5:26 pm
hi,
is anyone else having a problem with the speed of the blenderrender in this build?
regards.
jms
Post by jms » Sat Jan 06, 2007 6:18 pm
Just a note : Blender RC1 243 win32 and this build use exactly the same environment ( MSVC 7.1 ) for compilation .
mosesonline
Post by mosesonline » Sat Jan 06, 2007 7:23 pm
has anyone a problem with change form edit to object mode? I have a problem and blender crashes everytime. I tried to change some properties of the object light an mesh but nothing works it is since the rc1.:'( i always use jms builds.
http://www.mathematik.uni-marburg.de/~m ... thSD.blend
It's also interesting if it happens on other pc, too.
jms
Post by jms » Sat Jan 06, 2007 8:25 pm
Right, this file crashes here too .
jms
Post by jms » Sun Jan 07, 2007 7:04 pm
jms wrote:Right, this file crashes here too .
But it works with the today version .
thoro
Post by thoro » Tue Jan 23, 2007 2:07 pm
Hmm, tried to work with the new multilayer images feature. I am able to render a multilayer image but Blender (the CVS build as well as 2.43 RC2 / WindowsXP) crashes when I try to load the rendered image into the compositor.
Has anybody else tried this and had the same problem? Do I have to add some libraries to load multilayer images?
EDIT: reported to bug tracker
EDIT2: fixed by Ton :cool:
jms
Post by jms » Mon Mar 05, 2007 3:31 pm
Return to the old CVS zoo/build.
Different splash, icon and .B.blend.
poutsa
Post by poutsa » Mon Mar 05, 2007 6:35 pm
In the CVS Test Build Date:05/03/ if you add a Time Node in the Compositor Blender Crashes!
Can you confirm this JMS?
Thans
seeyA
jms
Post by jms » Mon Mar 05, 2007 11:23 pm
poutsa wrote:In the CVS Test Build Date:05/03/ if you add a Time Node in the Compositor Blender Crashes!
Thans
seeyA
I Confirm. With this build and with a cleaner one (a kind of RC) made this night.
