Bf-Blender 2.5 /Windows : build updated when needed.
poutsa
Post by poutsa »
The Widgets Manipulators not Works Ok !.....maybe a BUG!
Try to use as example in Scale Manipulator mode and Local Transform Orientation..... to Transform the Cube from Starting Scene!! Strange Results!
seeyA
Vassilios
jms
Post by jms »
Tested on win xp pro with the <<internal>> blend file, the manipulator seems to work correctly .
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
poutsa
Post by poutsa »
Tested on Windows Xp Pro also!......and not works OK!
I dont know Why!!? :(
poutsa
Post by poutsa »
I found the Problem!
I delete the stored B.Blend ...because i saved Default Setting from older Testing Build!
And now it WORKS GREAT.!!...not a bug!!The Manipulators Works Great!!
THANKS!....with the Internal blend file it works!!
mstram
Armature Layers
Post by mstram »
Greetings,
I downloaded this build yesterday and I'm trying to determine if I've found a bug with this build, or if it's a problem with the .blend file I'm trying to use.
First - Does this build have 'Armature Layers' built into it?
If it does, what / where are they in the User Interface ? :)
I've looked for docs on the MediaWiki and haven't been able to find anything.
Are they the sixteen buttons under ‘Display Options’ in the Armature tab and the sixteen buttons under the Armature Bones tab ?
If they are, then when using this rig either
a) the rig / armature layers are not working in this build
or
b) armature layers are not working with files created in the Linux CVS vs the Windows CVS
or
c) the specific CVS that Bassam used is the same version that everyone there (on Orange) that *is* seeing armature layers is using
or
d) ????????????
Mike
jms
Re: Armature Layers
Post by jms »
mstram wrote:Greetings,
Layers seem to be at their correct place :
and work, at least they show or hide parts of the armature :
http://orange.blender.org/blog/mancandy-updated#more-96
mstram
Post by mstram »
jms,
Ok, it's working.
I re-downloaded the rig.
I guess when I opened the file in a non-cvs version (current 2.41 "official download from and saved it, the 'armature layers" and the other "new bone-selectors" information was all erased-moved.
Mike
mstram
Re: bf- Windows (2006/04/26) MSVC (+ Win98 + modifiers pymod
Post by mstram »
bf-blender/ Windows, 2005/04/26, 21:10:00 (Paris meridian, Europe),
"2005" should be "2006" shouldn't it ?
I know it doesn't really matter, but it's a bit confusing.
Mike
jms
Post by jms »
Mike
Exact . That's springtime .
poutsa
Post by poutsa »
something wrong with Lamp Visualisation (drawing ) in 3D Window View in the last 29/4 Build!
vassilios
jms
Post by jms »
poutsa wrote:something wrong with Lamp Visualisation (drawing ) in 3D Window View in the last 29/4 Build!
vassilios
It seems to disappear when one opens the user preferences window .
Did you try the sequence editor ?
poutsa
Post by poutsa »
jms wrote:It seems to disappear when one opens the user preferences window .
Yes Thats Right!
No.but i test it later!
Thanks for this Builds! :D
Vassilios
jms
Post by jms »
jedrzej_s
Post by jedrzej_s »
Wow !!! This PyDrivers is very cool !!! We need more examples .blends with PyDrivers !!!!!!!!
jms
Post by jms »
jedrzej_s wrote:Wow !!! This PyDrivers is very cool !!! We need more examples .blends with PyDrivers !!!!!!!!
http://projects.blender.org/tracker/dow ... shes.blend and http://projects.blender.org/tracker/dow ... vers.blend
