bf blender / OS X - 2.40 RC1 (2005/11/29) RC BUILD
Official test builds :
choose the build depending of your installed python version
these builds wont work on 10.3.8 and earlier
OS X 10.3.9
OS X 10.3.9 + python 2.4
NVIDIAs users : we are especially interested on wether those builds work for you. they include partial workaround to the drawing problem
edit : unstikyied
OS X 10.3.9
edit : unstikyied
Test build doesn't work
The interface of Blender doesn't work on Mac osx 10.4.3 on Mac G5 Dual processor Nvidia Geforce fx 5200.
The previous releases in the testing build forum were working well.
ciao
ciao
UI Unresponsive
I just downloaded the package above (the non-python-2.4 one) and can confirm that on my Mac it has an issue. When it is first launched, the entire UI inside the main blender window is completely unresponsive (however, the Mac OS menubar did work, and I was able to quit the app with the mouse; I didn't have to force-quit it). However, if you resize the main window, the UI starts working again - the menus (blender generated, not the OS menus), widgets, etc start to respond to mouse clicks.
No regression was attempted. No other feature-testing has been attempted yet.
OS X 10.4.3, with all patches/updates as of 11.30.2005
867Mhz G4 "Quicksilver", 1.5GB Ram, 80GB HDD, with ~40GB free
From System Profiler:
Machine Name: Power Mac G4
Machine Model: PowerMac3,5
CPU Type: PowerPC G4 (2.1)
Number Of CPUs: 1
CPU Speed: 867 MHz
L2 Cache (per CPU): 256 KB
L3 Cache (per CPU): 2 MB
Memory: 1.5 GB
Bus Speed: 133 MHz
Boot ROM Version: 4.2.4f1
NVIDIA GeForce2 MX:
Chipset Model: GeForce2 MX
Type: Display
Bus: AGP
Slot: SLOT-1
VRAM (Total): 32 MB
Vendor: nVIDIA (0x10de)
Device ID: 0x0110
Revision ID: 0x00a1
ROM Revision: 1055
Displays:
Display:
Resolution: 1600 x 1200 @ 85 Hz
Depth: 32-bit Color
Core Image: Not Supported
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Number Of CPUs: 1
CPU Speed: 867 MHz
Memory: 1.5 GB
Bus Speed: 133 MHz
NVIDIA GeForce2 MX:
Type: Display
Bus: AGP
Slot: SLOT-1
VRAM (Total): 32 MB
Device ID: 0x0110
Revision ID: 0x00a1
ROM Revision: 1055
Displays:
Display:
Depth: 32-bit Color
Main Display: Yes
Mirror: Off
Online: Yes
This workaround makes things worse on my system (OS 10.4.3 + dual G5 + GeForce6800), as I noted in my last 3 posts in the bugtracker:NVIDIAs users : we are especially interested on wether those builds work for you. they include partial workaround to the drawing problem
https://projects.blender.org/tracker/?f ... 9&atid=125
Thanks for your hard work anyway, Luke! Hopefully there is a fix soon from Apple, since it affects so many applications.
problem on mac 10.4
I want to point out a problem. I guess it's been mentioned, but when I run blender from this Mac, the icon clicks, but doesn't start
Hardware Overview:
Machine Name: Power Mac G5
Machine Model: PowerMac7,3
CPU Type: PowerPC G5 (3.0)
Number Of CPUs: 2
CPU Speed: 2.3 GHz
L2 Cache (per CPU): 512 KB
Memory: 6.5 GB
Bus Speed: 1.15 GHz
Boot ROM Version: 5.2.4f1
Serial Number: G851429XRU3
NVIDIA GeForce 6800 GT DDL:
Chipset Model: GeForce 6800 GT
Type: Display
Bus: AGP
Slot: SLOT-1
VRAM (Total): 256 MB
Device ID: 0x0045
Revision ID: 0x00a1
ROM Revision: 2120
Displays:
Cinema HD Display:
Display Type: LCD
Resolution: 1920 x 1200
Depth: 32-bit Color
Core Image: Supported
Main Display: Yes
Mirror: Off
Online: Yes
Display:
Status: No display connected
Hardware Overview:
Number Of CPUs: 2
CPU Speed: 2.3 GHz
Memory: 6.5 GB
Bus Speed: 1.15 GHz
Type: Display
Bus: AGP
Slot: SLOT-1
Device ID: 0x0045
Revision ID: 0x00a1
ROM Revision: 2120
Displays:
Cinema HD Display:
Display Type: LCD
Depth: 32-bit Color
Main Display: Yes
Mirror: Off
Online: Yes
Display:
MacOS X 10.4.3 problem
I know that the problem I encountered is known. However, resizing the window doesn't help in my case.
To satisfy my curiosity: do you think that this problem is going to be resolved soon? Or do we have to wait until Apple solves it? By the way what is causing it?
I'll be reading this forum and I'll be happy to test a new build! I'm afraid that's all I can do to help...
Greetings,
Wim
PowerMac G4 733
macOS X 10.4.3
1.12 GB RAM
Greetings,
Wim
PowerMac G4 733
macOS X 10.4.3
1.12 GB RAM
Re: UI Unresponsive
i've had similar problems on the same machine - it seems to be due to the low-end graphic card with low ram. i always had to run the desktop in 16bit-mode ("Thousands of colors") to make blender run properly. maybe reducing resolution also might help (if you want millions of colours).hammerhead74000 wrote:I just downloaded the package above (the non-python-2.4 one) and can confirm that on my Mac it has an issue. When it is first launched, the entire UI inside the main blender window is completely unresponsive (however, the Mac OS menubar did work, and I was able to quit the app with the mouse; I didn't have to force-quit it). However, if you resize the main window, the UI starts working again - the menus (blender generated, not the OS menus), widgets, etc start to respond to mouse clicks. ...
marin
- Contact:
New Version?
Heya:
Not sure when the final version of 2.40 is due out, but I know there's been a lot of bugfixes done since this RC was posted. Any chance of getting an updated build?
Many thanks,
-Bish
Many thanks,
-Bish
- Contact:
New Build?
Heya!
Not knowing when the final 2.4 will be released, and knowing that a good bit of bug squashing has been going on, is there any chance of seeing a revised RC build?
Looking forward to final release but content to help debug until then,
-Bischofftep
-Bischofftep
i realize that i'm pushing my luck, but my g/f has an ibook G3, and the appllication fails to even run... I'm an apple noob, so excuse me please.
Hardware Overview:
Machine Name: iBook
Machine Model: PowerBook4,3
CPU Type: PowerPC 750 (2.3)
Number Of CPUs: 1
CPU Speed: 900 MHz
Memory: 256 MB
Bus Speed: 100 MHz
Boot ROM Version: 4.6.4f1
ATI Mobility Radeon 7500:
Chipset Model: ATY,RageM7
Type: Display
Bus: AGP
Slot: ATI
VRAM (Total): 32 MB
Vendor: ATI (0x1002)
Device ID: 0x4c57
Revision ID: 0x0000
ROM Revision: 113-XXXXX-210
Hardware Overview:
Machine Name: iBook
Number Of CPUs: 1
CPU Speed: 900 MHz
Memory: 256 MB
Bus Speed: 100 MHz
Type: Display
Bus: AGP
Slot: ATI
VRAM (Total): 32 MB
Device ID: 0x4c57
Revision ID: 0x0000
