bf-Blender / Linux (2005/08/02) FFMPEG support
gabio
Post by gabio »
Hi all. This is the ffmpeg integration done by Peter Schlaile. Note this is not yet available for Windows.
Builded in scons with the following command:
scons WITH_BF_FFMPEG=1 BF_FFMPEG_INC=/usr/include/ffmpeg
BF_FFMPEG_LIB='avformat avcodec avformat avcodec avutil vorbis vorbisenc
theora ogg dts a52 raw1394 z'
note: if it fail to start make sure you have all lib installed: ffmpeg,vorbis, theora, ogg, dts, raw1394
Overall:
-Sequencer kinda rewrite & speedup
-FFMPEG support. So this mean avi codec, mpeg and mov support on linux.
-Better sound support
-auto multiplex of video and sound in sequencer output.
-Some new effects
-a frame server
-Frame count can go up to 300k now.
-Some more improvement in compositing.
-Nice vector blur node.
-multithread bugfix.
and a lot more!
http://www.graphicall.org/builds/builds ... show&id=89
OTO
Post by OTO »
Thanks Gabio
at least an oriented sound version!!!! Hooooray!!
But...( always a but :) ) I can't get to install the "dts" thing
Only a dts-dev for Debian that don't have the needed libdts.so.0
Any tips?
Bye
kidb
Post by kidb »
OTO wrote:Thanks Gabio
Any tips?
Bye
ln -s /path/to/libdts.so.x.x /path/to/libdts.so.0
OTO
Post by OTO »
Hello kidb
thank you, it was a nice try :)
The problem is that I don't have any libdts.so ( debian sarge)
I have a libdts.a, a libdts_plugin.so and the like
And even worst I can't find it anywhere in the Web
Bye
bobbin
Post by bobbin »
Have you tried to compile the dts-dev ?
I assume it is the source for dts itself, isn't it ?
gabio
Post by gabio »
sadly only debian have this -dev thing
for debian the lib is called libdts_pic.so or something. Anyway I linked against libdts.so
maybe build dts-dev and ln libdts_pic to libdts.so?
butelo
Post by butelo »
I used libgstdtsdec.so from gstreamer package in my Ubuntu 5.10 Breezy Badger located in /usr/lib/gstreamer-0.8/ for libdts
it worked
congratulations for all blender work!!!
OTO
Post by OTO »
Hey butelo
thanks/gracias/obrigado :)
It works now
OTO
Post by OTO »
Hi again
something wrong with Share Vertex colors function- Vkey?!
torax
Post by torax »
hello,
Im very new to blender and linux... what do I need to do to run this test on my RHEL 4?
when I run the "executable" a lot of libraries are missing. do I have to compile it from source?... where is the source?
OTO
Post by OTO »
Hello
no, no it's quite easy
go easy, each library at a time
Ex: libsomething.so.0 you don't have it?
Search in your hard drive if you have a libsomething.so.something
If you have it make a symbolic link to it
ln -s libsomething.so.something libsomething.so.0
try to run Blender
Now the one above shouldn't appear in the missing
Bye
kxs
Post by kxs »
I get this after I try to run this build:
Code: Select all
./blender: error while loading shared libraries: libgettextlib-0.14.4.so: cannot open shared object file: No such file or directory
I tried to find which package I need using this site:
http://packages.ubuntu.com/
but unfortunately I get this message:
You have searched for libgettextlib-0.14.4.so in breezy, architecture i386.
Can't find that file, at least not in that distribution and on that architecture.
What should I do than? :?
torax
Post by torax »
yeah, Im having problems with the same libraries... can someone upload the right one?
thnx!
OTO
Post by OTO »
Hello
Ah, Linux is so funny :)
In Debian this file is in the gettext package
Maybe you have a different number version
No problem, make a symbolic link to the needed number
Bye
madman
Post by madman »
I use Kubuntu, gettext give me the 0.14.5 v of the lib so i write:
sudo ln -s libgettextlib-0.14.5.so libgettextlib-0.14.4.so
in /usr/lib folder
c ya!
