BF Windows 2006/02/27 : fluid sims updated
lucky3
Post by lucky3 »
ucky3,kmaro: so you get fluid meshes that look like that, when you set the domain boundary to "noslip"? That looks really strange...
Hum i've experienced that bug one more time and the 'noslip' feature doesn't change anything...weird. However i've noticed that the bug only happens with Final meshes, Preview meshes works right.
n_t
Post by n_t »
lucky3: i still havent come across this problem, maybe you can post the file where it happens?
thanks
-> Nils
ZanQdo
Post by ZanQdo »
HI, I got the same problem, this file even crashed cvs :(
http://www.3developer.com/temp/FluidBug.blend
:-) Hosting for your test builds:
GraphicAll.org
ZanQdo
Post by ZanQdo »
Sorry for double post, here's another file crashing, I can't make a single sing with cvs fluids, I'm using old linux test vercion Sad
http://www.3developer.com/temp/GotaBaker.blend
GraphicAll.org
monkeyman23555
Post by monkeyman23555 »
Hi
Em With the new fluid sim I get that bug all the time just set your view in the 3d to preview and the render to final and it will work fine with anything i think...
BTW N_T GREAT!
None for the current moment.
monkeyman23555
sorry the preview think only works some times :(
but why are the baking times so slow to bake:
115 frames = 40 mins
then continuing
145 = another 30 mins?
n_t
Post by n_t »
monkeyman23555: The baking times depend on the resolution setting, which determines the "number of equations" you have to solve, so there's simply a lot of stuff to compute... :)
ZanQdo: Thanks for the files, I tried both with my Linux build, and a recent win32 build (http://blendertestbuilds.de/index.php?d ... 0060308.7z) - it seems to work, I can bake, the finnal mesh is displayed in the GUI (preview is "off" in the files) and render it... Switching the preview generation on also seems to be fine. Maybe you can check if it works for you with that version?
Thanks,
-> Nils
ZanQdo
Post by ZanQdo »
Yes nils, it works perfectly now thank you very much :D
GraphicAll.org
