Hello RRuiz, can you make a patch of your projects, I know there is the source in archive, but a patch is simpler.
I would like to help you, I'm not a C coder (I program a little in pascal and begin to understand C).
RRuiz wrote: letme take a look at . . it have a problem when you reduce the render % because now the size are in diferent place . I'm workin on that . . . .
dame mas datos please, cuando exactamente? , cuando cambias el % o no? , dame mas detalles porfa
Crash in every scene.
No he cambiado nada, con cualquier escena Blender da un error al terminar el render y sale a windows.
mfoxdogg wrote:I don't mean to be annoying, but do you have POVray's permission to do this?
their licence is rather dubious
Well I put the progam in his support area , and what I understud from the licence the thing you can not do is include pov inside your code as a part of a total. so I thing we are ok. If you understand something else please letme know
Un Saludo
Caronte, is wird , it work for me, try to deactivate the execute pov just to generate the pov files, and see if the error is in the imagen loading . . . I think thats where the problem is.
RRuiz wrote:Caronte, is wird , it work for me, try to deactivate the execute pov just to generate the pov files, and see if the error is in the imagen loading . . . I think thats where the problem is.
Yes, this way works fine.
Then, The error occurs when Blender try to load the Pov image.
