BF Windows 2006/03/26
lguillaume
Post by lguillaume » Sun Mar 26, 2006 6:08 pm
Hello new compilation with a little patch I made:
When you add a mesh (plane, cirlce, ...) and press NKey, properties says size=1.0 but the mesh does not have this size in blender unit, a plane have a width and a height = 2.0, a circle have diameter of 2,83
I change to have for a plane, cube a width height=1 and for circle,tube, cone, cylinder and UVSphere a diameter of 1 so when you play with size, you scale exactly the number you typed.
Download:
7zip 2.2MB
zip 2.9MB
ElBarto
Post by ElBarto » Sun Mar 26, 2006 6:35 pm
SizeX,Y,Z means ScaleX,Y,Z and that is one of the oldest usability mistakes in Blender. I remarked it too but as many time "Its not a bug, its a feature" :)
Anyway renaming it to Scale would be the right way (the key S is explained for "Scale" and not as "Size").
Thanks for the new built.
Karamba!
Bart.
http://www.area42.de/
Blender Feature Proposal:
http://www.neeneenee.de/blender/features/
lguillaume
Post by lguillaume » Sun Mar 26, 2006 7:20 pm
Hello ElBarto, I know for scale, if we change all size by scale the problem is the same, a circle of a diameter of 2.8 blender units is hard to use if you want exactly a diameter, with this, the circle created have a diameter of 1 blender unit so if you want a circle of diameter 5.4 you only have to scale to 5.4
Actually to do this you have to spin a vertice, hard to a beginner.
ElBarto
Post by ElBarto » Mon Mar 27, 2006 10:09 pm
In my understandment (based on the knowledge of various 3d technologies and 3d software) the size depends on units but not the scaling.
A object can have the radius or lenght of 5.34, which means 5.34 units, but nevertheless the scaling factor is 1. Scaling is independent of units, it is just a factor. Size gives you the dimension of the created object (or maybe the edited mesh) and Scale is just a modification factor.
This model is working on VRML/X3D too.
Karamba!
Bart.
mfoxdogg
Post by mfoxdogg » Tue Mar 28, 2006 7:00 am
HI fellas great build, the 'white out' effect of renders is caused by something in the Ambient Occlusion
Please Fix it :D
I reject reality and substitute my own!!
Rickyx
Re: BF Windows 2006/03/26
Post by Rickyx » Tue Mar 28, 2006 2:58 pm
Finally... great built. I agree that is important the absolute diameter!
Anyway, if it won't become the standard remember the formula
r2=r1 cos alfa
where alfa = 360/2 *number of sides of the poligon
Ciao,
Ricky
Digital FX Artist
Size and Scaling in Maya and Blender
Post by Digital FX Artist » Wed Mar 29, 2006 3:18 am
Hi guys,
I have looked at both blender an maya. In maya when you create an object it is a unit of 1 in width, height and depth. This means if you create a cube and a cylinder, the cube and the cylinder will be the exact same width, height and depth, they will match exactly. In blender this doesn't happen. If you have correctedly this, congrats.
Digital FX Artist
Digital FX Artist
Post by Digital FX Artist » Wed Mar 29, 2006 3:22 am
Hi guys,
Digital FX Artist
