bf-blender / OS X (pre2.42 test build)
lukep
Post by lukep »
hi,
here is a fresh build from CVS
http://jlp.nerim.net/dev/Blender-PRE2.42-osx-ppc.zip
LetterRip
Post by LetterRip »
much appreciated,
LetterRip
AndyD
Post by AndyD »
Thanks Lukep. I guess this release doesn't contain ffmpeg and muxing support? If it does, can you point to any links that explain how to access these new output options?
Andy D
I'm a great speller but a hopless tpyist
badcheese
synced animation playback broken
Post by badcheese »
Thanks Luke. Here's a bug:
1. Go to Scene Buttons (F10), Anim/Playback Buttons context (the squiggly arrow).
2. Turn on "Sync" button (doesn't matter if there's any audio in the scene).
3. In 3D window, start animation playback (Alt+A).
It's been broken in CVS for a little while, but I can't post in the bug tracker because my browser times out waiting for the server to respond.
-Randall
AndyD
Post by AndyD »
Hi Randall,
What's "broken" exactly? What does/doesn't it do?
Andy D
badcheese
Post by badcheese »
Sorry for not explaining. I thought my subject line said enough.
The animation playback is broken. Instead of playing back the animation, it just flickers between the first frame and some extremely high frame number (which is not the last frame). The frame number in the cursor looks like 3647, but if I hit the spacebar to stop it seems to be 300000.
Does it only happen to me?
badcheese
Post by badcheese »
I was finally able to post a bug report for it:
http://projects.blender.org/tracker/ind ... 9&atid=125
AndyD
Post by AndyD »
Just tested this latest version as per your instructions and I'm not seeing any similar problem (OS10.3.9/Py2.3).
Out of interest, does it mess up if you press the sync button in the soundblock context screen instead?
Andy D
badcheese
Post by badcheese »
Thanks for testing, Andy.
Those buttons apparently set the same flag. One cannot be turned on without the other turning on as well. So yes, the sound block Sync button has the same effect.
When bugs only happen to me, it's usually because I have 2 CPU's. Sometimes it's because I have nVidia graphics. I bet this time it's because of the dual processors.
badcheese
Post by badcheese »
If you want to see the bug, try the .blend file from my bug report:
http://projects.blender.org/tracker/dow ... sync.blend
AndyD
Post by AndyD »
Ahhh, I see. You haven't got an audio frequency selected - that seems to fix it.
My Blender has 44.1Khz selected by default, even with no audio imported.
Admittedly, it would be nice if it threw up an error message instead of doing what it does do.
Andy D
binary_ranger
Menu problems on new macbook
Post by binary_ranger »
I'm having a problem with recent OS X builds of blender similar to the problem that showed up in 10.4.3 with glDrawBuffer(GL_FRONT). The menus do not draw, but are still technically functional, just really hard to use!
I've got a white Macbook 1.83 Ghz w 2 gb ram. I would guess it's a problem with the integrated intel 950 chipset, but it's worth noting.
Keep up the good work
binary_ranger
Menus - partially fixed on Macbook
The menus now show up in the 2.4.2 RC2 version, although the shadows are red and green. but that i can deal with now that I can see where I'm going.
