Built in Windows with Cygwin/Make, in an Athlon x2 3800+.
CVS from a minutes ago
New great feature from Ton:
Log:
Animation department feature request: support for vertex groups in Lattices
In a quick glance: (temp image)
http://www.blender.org/bf/rt.png
Main reason is that Lattices are useful a lot for Armature deformation.
Lattices just provide much more precise and interesting control. However,
with only bone envelopes it's very hard to use.
Working with Lattice vertex groups is nearly identical to Mesh:
- on CTRL+P 'make parent' you can choose the deform option now
- In editmode, the buttons to control vertex groups are available
- In outliner you can select vertexgroups too
- Deforming Lattices with Armatures has all options as for Mesh now.
Note:
- No WeightPaint has been added yet. To compensate, the editmode
drawing for a Lattice with vertex group shows weight values for the active
vertex group.
- Lattice editmode doesn't undo/redo weight editing yet.
- Softbody for Lattice still uses own vertex weights
Implementation notes:
- derivedmesh weight_to_rgb() is now exported to drawobject.c
- been doing cleanups in code (order of includes, var declarations, etc)
- weightpaint button handling now is generic
Notes:
No Game Engine.
A little patch I tweaked based on another, lets you choose your size of render up to 1000% with a little slider, and OSA levels from 2 to 16.
Download!
http://www.graphicall.org/builds/builds ... how&id=253
If you don't like my theme (I bet you wont
Cheers!
