[windows 060929] Blender4Yafaray and sculptmode patch
lguillaume
Post by lguillaume » Fri Sep 29, 2006 11:57 am
Hello, I make a new compilation with 2 patch:
- Project SoC sculptmode, there is some bugs with texture brush, but does not crash on my computer
- Yafaray a branch of Yafray by Lynx3D : doc
Note : to used Yafaray disable XML, if XML is enabled you use Yafray.
Downloads :
Yafaray setup (725kB)
Blender compressed with 7zip(2.38MB)
Blender compressed with zip(3.18MB)
poutsa
Post by poutsa » Fri Sep 29, 2006 1:26 pm
Hallo lguillaume.....Thanks for this Builds!
Question:I made the Registry changes manual for Yafaray like you explain in other post........so now there is a Setup for Yafaray...so my Question is: can i Install the Yafaray Setup without delete the Changes i made manually in the Registry for Yafray Team-Yafaray??
or i must delete this keys in the registry bevor i Install the Setup?
Thanks
lguillaume
Post by lguillaume » Fri Sep 29, 2006 1:32 pm
poutsa wrote:Hallo lguillaume.....Thanks for this Builds!
Thanks
I don't try but I think you can run the setup without erasing the key.
poutsa
Post by poutsa » Fri Sep 29, 2006 1:39 pm
Thanks for your Answer.!!!
...anyway i erase the Registry Key and i Installed the Yafaray Setup and it Works Great!!
Thanks!!
