The Good Got Better
...and what was not good, got fixed!
The much anticipated update of the Blender 2.80 milestone is here! With over a thousand fixes and several important updates that were planned for the 2.8 series. Most notable are the sculpting tools overhaul, support for NVIDIA RTX ray tracing in Cycles, Intel Open Image denoising, a better outliner, a new file browser and much more.
Sculpting Rethought
A complete overhaul of the sculpting workflow.
Read more
New Cursor & Brush Settings
Auto Masking
Assigns a factor to each vertex before starting the stroke. Topology automasking affects only vertices connected to the active vertex.
World Spacing
Keep an even distance between stroke points in 3D space. Great for sculpting near the edges.
Grab Active Vertex
Snaps the maximum strength of the grab brush to the highlighted active vertex, making it easier to manipulate low poly models or meshes with subdivision surfaces.
Normal Radius
Control how sensitive the sculpt normal direction is to the underlying surface.
The cursor now is aligned to the surface normal, displays symmetry and a preview curve fall-off.
Displays the edges of the mesh inside the brush radius. This helps to visualize the real geometry the user is manipulating from sculpt mode when there are active modifiers.
Masking
Mask Filter
Modifies the whole paint mask. In includes multiple operations like smooth, grow or contrast accessible from a pie menu.
Dirty Mask Generator
Similar to Dirty Vertex Colors, but it generates a paint mask. It can be used to mask cavities in the sculpt.
Mask Expand
Creates a mask from the active vertex to the vertex under the cursor based on topology or mesh curvature.
Mask Extract
Extracts the paint mask to a new mesh object. It can extract the paint mask creating a boundary loop in the geometry, making it ready for adding a subdivision surface modifier.
New Tools
Pose Brush
Pose a model simulating an armature-like deformation. The pivot point for rotation is calculated automatically based on the radius of the brush and the topology of the model.
Elastic Deform Brush
Based on Pixar's paper Regularized Kelvinlets:
Sculpting Brushes based on Fundamental Solutions of Elasticity
, this tool lets you grab, biscale grab, triscale grab, scale and twist operations while preserving volume.
Translate, Rotate, Scale
Use the familiar transform tools now also during sculpt. Transforming around a pivot point and taking into account symmetry.
Draw Sharp Brush
Similar to the draw brush, but it deforms the mesh from the original coordinates. When used with the sharper curve presets it has a much more pleasant crease/cut behavior than any of the other brushes. It is useful for creating cloth wrinkles, stylized hair or hard surface edges.
Mesh Filter Tool
Applies a deformation to all vertices in the mesh at the same time. It includes multiple deformation modes and the option to lock the deformation axis.
Remeshing
Blender 2.81 now ships with two new ways to remesh your models, a fast one based on volumes and another one preserving quads.
Read more
OpenVDB Voxel
Quickly create a new quad mesh based on the volume of the mesh. It is particularly useful for sculpting, to generate a good topology when blocking shapes, as an alternative to dynamic topology without the performance cost of continuous updates.
QuadriFlow
Creates a quad mesh with few poles and edge loops following the curvature of the surface. This method is relatively slow but generates higher quality for final topology.
Intel® Open Image Denoise
A new Denoise node was added in the compositor, to denoise renders using OpenImageDenoise.
Compared to the existing denoiser, it works better with more complex materials like glass, and suffers less from splotchy artifacts. It also gives better results with very low numbers of samples, which can be used for quick previews.
Read more
4 Samples Without Denoise 4 Samples Without Denoise
4 Samples With Denoise 4 Samples With Denoise
Cycles
Not everything is EEVEE these days! Cycles got new and improved nodes, a new denoiser, adaptive subdivision stitching, custom HDRI picking from the viewport, NVIDIA RTX support and optimizations all over the board.
Read more
Preview Passes in the Viewport
Pick which pass to see while in Rendered shading mode.
Massive improvements on Shader nodes for Cycles & EEVEE.
Volume Info
For convenient access to Color, Density, Flame, and Temperature attributes of smoke domains.
Vertex Color
For convenient access to Vertex Colors and their alpha channel.
Map Range
Linearly remap a value from one range to another.
White Noise
Produces a random number based on input values.
Clamp
Clamps a value between a maximum and a minimum values.
Math & Vector Math
New operations and dynamically show number of inputs depending on the operation.
Mapping
Location, rotation and scale are now node inputs that can be linked to other nodes.
Voronoi, Musgrave, Noise
Support for 1D, 2D, and 4D textures. Plus more feature types.
Reduced shadow terminator artifacts for bump mapping with diffuse BSDFs.
Blender 2.80 Blender 2.80
Blender 2.81 Blender 2.81
NVIDIA RTX Support
NVIDIA RTX Support
Cycles now has experimental support for rendering with hardware-accelerated raytracing on NVIDIA RTX graphics cards. It’s On.
The OptiX backend was contributed by NVIDIA.
EEVEE
After making its debut in Blender 2.80, the real-time render engine got major optimizations and new features in this release.
  • Soft Shadows have been completely rewritten to be easier to setup, look and match Cycles better.
  • Volumetrics are now faster to compute on modern GPUs.
  • Bump mapping gives more accurate results closer to Cycles.
  • Support for instanced lights and shadow casters.
  • Contact shadows now follow the light shape.
  • Sun lights now have their clip distances automatically computed.
  • Holdout is now supported with both opaque and semi transparent surfaces.
  • Transparency handling has been reworked and now supports the same BSDF combinations as Cycles.
Read more
Grease Pencil
New brushes, improved stroke quality, new tools and performance improvements.
Read more
New Brushes & Presets
Self Overlap
Self Overlap
A new option in materials to disable the stencil effect on strokes.
Isometric Guides
Isometric Guides
New isometric grid option for lines specified by angle.
New File Browser
  • Opens as floating window with more standard layout.
  • Popovers for view and filter options.
  • Reworked display of date and file size text.
  • Options now display on the sidebar, opened or closed depending on the task.
  • Vertical list view with interactive column header.
  • Deleting files will now move them to the system trash.
  • New and updated icons.
  • Some settings of the dialog are saved in the preferences, so reopening it will have them remembered.
  • Preferences option allows using the File Browser in full-screen layout.
Read more
Outliner
The outliner got a long-overdue pass on usability.
  • Selection is now synced with the viewport
  • Range selection with Shift+Click, extend selection with Ctrl+Click, and range select without deselecting with Ctrl+Shift+Click.
  • Drag & Drop for parenting multiple objects.
  • Navigate with Up and Down keys, expand/collapse with Left/Right, hold shift to apply recursively
  • Box select with click and drag.
  • Expand arrow click and drag to expand or collapse multiple items.
  • Object selection with eyedropper now works in the outliner.
  • Filter option to show hidden objects.
  • F2 to rename active outliner element.
Read more
Transform & Snapping
Transform origins, new snapping, mirroring and auto merge options.
Read more
Transform Origin
It's now possible to move object origins directly. This is an alternative method of adjusting the origin, previously only possible placing the cursor and setting an objects origins to the cursor.
Snapping
Two new snap options have been added:
  • Edge Center, to snap to the middle of an edge.
  • Edge Perpendicular, to snap to the nearest point on an edge.
Transform Parent
You can now transform parents without affecting their children.
Mirror Any Axis, Anywhere.
For mesh editing and vertex/weight paint modes, mirroring now supports X, Y, Z and multiple axes simultaneously.
Poly Build Improvements
Blender 2.81 brings the poly build tool to a whole new level for retopology tasks.
Library Overrides
Library Overrides is the new system designed to replace and supersede Proxies.
Most types of linked data-blocks can be overridden, and the properties of those overrides can then be edited.When the library data change, unmodified properties of the override one will be updated accordingly.
Compared to proxies, library overrides support:
  • Multiple independent overrides of the same linked data (i.e. link a character once, instance it multiple times!).
  • Adding new modifiers and constraints, anywhere in the stack.
  • Recursively chaining overrides (i.e. link and override overrides from another library file, etc.).
Viewport
The viewport and workbench also got improvements in this release.
Read more
Local Collections
Each viewport can now have its own set of visible collections.
Specular Control on Matcaps
Workbench matcaps can now be OpenEXR images with separate diffuse and specular layers.
Mesh Analysis
Mesh analysis overlay now supports meshes with modifiers, instead of only the original mesh.
Image Objects
Image objects can now be set to display only in side views for a better workflow when used as reference.
HDRI Strength Control
HDRI studio light strength can now be controlled in the shading popover.
Rendered Shading
Improvements were made to rendered preview so it supports turning off all scene lights and custom world HDRI, for look development (now also for Cycles!)
Batch Rename
Where you could previously rename the active item with F2, you can now also batch rename all selected items with Ctrl F2.
  • Find & replace with regular expressions
  • Set prefix or suffix
  • Strip characters
  • Change capitalization
  • Filter by data type
Stay up-to-date
Follow the official hashtag for Blender stuff on social media #b3d
Blender Development Fund
The donation program to support maintaining and improving Blender, for everyone. Become a member for as little as €5 per month.
