How to add points to edges ?
Jenifer
Post by Jenifer »
How to add points to edges ? instead of doing ctrl + r then deleting the edge to get the points.
Daniel90
Post by Daniel90 »
wow, I didn't knew that the technique you described actually works.
I tried it and seemed to get an n-gon. Even in wireframe mode it looked still like an n-gon. I thought this was not possible in Blender :?:
But it was such a weird building that I couldn't add a face to it.
Jenifer
Post by Jenifer »
instead of extruding from the edge, how to add vertex to an edge ?
m.ardito
Post by m.ardito »
Jenifer wrote:instead of extruding from the edge, how to add vertex to an edge ?
hi if i get it well...
1: select the edge
2: press Wkey (specials)
3: press subdivide (you get one more vertex) or
press subdivide multi (and then chooxse how many times)
mearvk
Post by mearvk »
Same question. Is it possible to add multiple vertices to an edge without Blender adding connecting edges?
psullie
Post by psullie »
not until 2.50 is released, see the article on Bmesh in 2.5 in Blender Nation
mearvk
Post by mearvk »
I figured out that if you aren't yet dealing with faces then you can subdivide edges without Blender connecting other vertices.
