Index of models and donut model
chaz
Post by chaz »
Would it be possible to have an index of shared 3d models on this site, or is there already one (couldn't find one)?
Can someone point me to a tutorial/document that shows how to make a donut/hula hoop type of model in blender?
Thanks!
Chaz
z3r0_d
Re: Index of models and donut model
Post by z3r0_d »
chaz wrote:Can someone point me to a tutorial/document that shows how to make a donut/hula hoop type of model in blender?
space->add->nurbs->donut?
chaz
donut model
Post by chaz »
z3,
I don't have space/add/nurbs/donut in 2.37a. I tried space/add/surface/nurbs donut, but it rendered out as a cube.
What am i doing incorrectly? Just looking for the wireframe donut.
Thanks for your help.
chaz
Nevermind, sorry
Post by chaz »
It came out right this time. Had to shut down blender and restart.
thanks for the help.
chaz
scaling donut
Post by chaz »
now that i have the donut, I need to reduce the diameter of it to make it more like a hula hoop. Any suggestions? I was able to flatten it with scale, but not reduce the width so it's skinny all around.
thanks!
z3r0_d
Re: scaling donut
Post by z3r0_d »
chaz wrote:now that i have the donut, I need to reduce the diameter of it to make it more like a hula hoop. Any suggestions? I was able to flatten it with scale, but not reduce the width so it's skinny all around.
thanks!
yes, that unfortunately is not really trivial
what about starting with an empty mesh, adding a circle, and using the spin tool?
LetterRip
Post by LetterRip »
use shrink/fatten
LetterRip
madcello
Post by madcello »
Make 2 bezier circles, a large one (diameter) and a small (thikness of the ring). Select the bigger one, hit F9 and find "Bev ob:". Write in there the name of the small circle (object name). That's it. If you want it bigger, edit the large circle, if you want it thinner or fatter, edit the small circle.
Tip: Play with "DefResolU:" first, witch is in F9, in both circles, if you want to convert to mesh.
p.s. this is the development forum of Blender, for users questions go to http://www.elysiun.com
