how to change wall thickness in Tube object?
drizzle
Post by drizzle »
Is anybody know how to change a wall thickness in Tube object?
teachtech
Post by teachtech »
In edit mode, select all verticies, type "E" to extrude, then "S" to scale them. Scale them in or out a bit to desired wall thickness. This will taper the ends a bit, but can be fixed by moving the end verticies. Hope this helps :D
Spectre-7
Post by Spectre-7 »
This technique is a little easier, I think. After you've selected all faces (Face Mode -> A), hit 'E' to extrude and then immediately click LMB to complete the extrusion. Now tap 'ALT-S' to shrink/fatten (aka Scale along Normals). With this method, the faces won't be tapered - They'll be exactly the same size as the faces they were extruded from.
Cheers!
AndyD
Post by AndyD »
Edit: Not paying attention :(
If the taper you refer to is the angled faces on the ends then just scale with S-Key, Shift-Z to prevent scaling along Z-Axis (assuming vertical tube).
Andy D
I'm a great speller but a hopless tpyist
